multi_distinct_sum
返回 expr 中去除重复值后的总和,功能等同于 sum(distinct expr)。
multi_distinct_sum(expr)
epxr: 用于指定参与运算的列。列值可以为 TINYINT,SMALLINT,INT,LARGEINT, FLOAT,DOUBLE,或 DECIMAL 类型。
列值和返回值类型的映射关系如下:
- BOOLEAN -> BIGINT
- TINYINT -> BIGINT
- SMALLINT -> BIGINT
- INT -> BIGINT
- BIGINT -> BIGINT
- FLOAT -> DOUBLE
- DOUBLE -> DOUBLE
- LARGEINT -> LARGEINT
- DECIMALV2 -> DECIMALV2
- DECIMAL32 -> DECIMAL128
- DECIMAL64 -> DECIMAL128
- DECIMAL128 -> DECIMAL128
-- 创建一张表,该表只有一个 int 域。
CREATE TABLE tabl
(k0 BIGINT NOT NULL) ENGINE=OLAP
DUPLICATE KEY(`k0`)
DISTRIBUTED BY HASH(`k0`)
PROPERTIES(
"storage_format" = "DEFAULT"
-- 插入值 0,1,1,1,2,2。
MySQL > INSERT INTO tabl VALUES ('0'), ('1'), ('1'), ('1'), ('2'), ('2');
Query OK, 6 rows affected (0.15 sec)
-- k0 的值去除重复后为 0,1,2, 将其相加得到 3。
MySQL > select multi_distinct_sum(k0) from tabl;
| multi_distinct_sum(k0) |
| 3 |
1 row in set (0.03 sec)
