版本:Candidate-4.0
count_if
计算满足指定条件(即条件表达试的结果为 true)的记录数。
该函数不支持 DISTINCT,举例:count_if(DISTINCT x)
该函数会内部转化为 COUNT + IF:
  • 转化前:COUNT_IF(x)
  • 转化后:COUNT(IF(x, 1, NULL))
COUNT_IF(condition)
condition: 条件表达式。可以在一条语句中指定多个 count_if 条件。
返回一个整数数值。如果没有匹配的记录,返回 0。该函数忽略 NULL 值。
假设有表 test_count_if
CREATE TABLE `test_count_if` (
`v1` varchar(65533) NULL COMMENT "",
`v2` varchar(65533) NULL COMMENT "",
`v3` datetime NULL COMMENT "",
`v4` int null
DUPLICATE KEY(v1, v2, v3)
PARTITION BY RANGE(`v3`)
(PARTITION p20220418 VALUES [("2022-04-18 00:00:00"), ("2022-04-19 00:00:00")),
PARTITION p20220419 VALUES [("2022-04-19 00:00:00"), ("2022-04-20 00:00:00")),
PARTITION p20220420 VALUES [("2022-04-20 00:00:00"), ("2022-04-21 00:00:00")),
PARTITION p20220421 VALUES [("2022-04-21 00:00:00"), ("2022-04-22 00:00:00")))
DISTRIBUTED BY HASH(`v1`) BUCKETS 4;
INSERT INTO test_count_if VALUES
('a','a', '2022-04-18 01:01:00', 1),
('a','b', '2022-04-18 02:01:00', NULL),
('a',NULL, '2022-04-18 02:05:00', 1),
('a','b', '2022-04-18 02:15:00', 3),
('a','b', '2022-04-18 03:15:00', 7),
('c',NULL, '2022-04-18 03:45:00', NULL),
('c',NULL, '2022-04-18 03:25:00', 2),
('c','a', '2022-04-18 03:27:00', 3);
SELECT * FROM test_count_if;
| v1 | v2 | v3 | v4 |
| a | NULL | 2022-04-18 02:05:00 | 1 |
| a | a | 2022-04-18 01:01:00 | 1 |
| a | b | 2022-04-18 02:01:00 | NULL |
| a | b | 2022-04-18 02:15:00 | 3 |
| a | b | 2022-04-18 03:15:00 | 7 |
| c | NULL | 2022-04-18 03:25:00 | 2 |
| c | NULL | 2022-04-18 03:45:00 | NULL |
| c | a | 2022-04-18 03:27:00 | 3 |
示例一:计算表中 v2 列的值为 NULL 的行数。
select count_if(v2 is null) from test_count_if;
| count_if(v2 IS NULL) |
| 3 |
示例二:计算满足条件 v1 >= v2 or v4 = 1 的行数。
select count_if(v1 >= v2 or v4 = 1)from test_count_if;
| count_if((v1 >= v2) OR (v4 = 1)) |
| 3 |
示例三:指定多个 count_if 条件。
select count_if(v1 >= v2), count_if(v1 >= v2 or v4 = 1), count_if(v1 >= v2 and v4 = 1)
from test_count_if;
| count_if(v1 >= v2) | count_if((v1 >= v2) OR (v4 = 1)) | count_if((v1 >= v2) AND (v4 = 1)) |
| 2 | 3 | 1 |
