SHOW PARTITIONS
SHOW PARTITIONS displays partition information, including common partitions and temporary partitions.
This syntax only supports StarRocks tables (
"ENGINE" = "OLAP"). Since v3.0, this operation requires the SELECT privilege on the specified table. For v2.5 and earlier versions, this operation requires the SELECT__PRIV privilege on the specified table.
Description of return fieldsβ
-- In shared-nothing cluster
| PartitionId | PartitionName | VisibleVersion | VisibleVersionTime  | VisibleVersionHash | State  | PartitionKey | Range | DistributionKey    | Buckets | ReplicationNum | StorageMedium | CooldownTime        | LastConsistencyCheckTime | DataSize | IsInMemory | RowCount |
-- In shared-data cluster
| PartitionId | PartitionName | CompactVersion | VisibleVersion | NextVersion | State  | PartitionKey | Range | DistributionKey | Buckets | DataSize | StorageSize | RowCount | EnableDataCache | AsyncWrite | AvgCS | P50CS | MaxCS | DataVersion | VersionEpoch       | VersionTxnType |
| Field | Description |
| PartitionId | The ID of the partition. |
| PartitionName | The name of the partition. |
| VisibleVersion | The version number of the last successful load transaction. The version number increases by 1 with each successful load transaction. |
| CompactVersion | The version number of the last successful compaction. |
| VisibleVersionTime | The timestamp of the last successful load transaction. |
| VisibleVersionHash | The hash value for the version number of the last successful load transaction. |
| State | The status of the partition. Fixed value: Normal. |
| PartitionKey | The partition key that consists of one or more partition columns. |
| Range | The range of the partition, which is a right half-open interval. |
| DistributionKey | The bucket key of hash bucketing. |
| Buckets | The number of buckets for the partition. |
| ReplicationNum | The number of replicas per tablet in the partition. |
| StorageMedium | The storage medium to store the data in the partition. The value HHDindicates hard disk drives, and the valueSSDindicates solid-state drives. |
| CooldownTime | The cooldown time for data in the partition. If the initial storage medium is SSD, the storage medium is switched from SSD to HDD after the time specified by this parameter. Format: "yyyy-MM-dd HH:mm:ss". |
| LastConsistencyCheckTime | The time of the last consistency check. NULLindicates no consistency check was performed. |
| DataSize | The size of data in the partition. |
| IsInMemory | Whether all data in the partition is stored in memory. |
| StorageSize | The size of storage the partition actually occupied. For shared-data clusters only. |
| RowCount | The number of data rows of the partition. For shared-data clusters only. |
| EnableDataCache | Whether Data Cache is enabled. For shared-data clusters only. |
| AsyncWrite | Whether Asynchronous Write is enabled. For shared-data clusters only. |
| AvgCS | The average Compaction Score of the partition. For shared-data clusters only. |
| P50CS | The P50 Compaction Score of the partition. For shared-data clusters only. |
| MaxCS | The maximum Compaction Score of the partition. For shared-data clusters only. |
| DataVersion | The version number of loading transactions. Compaction operations are not included. |
| VersionEpoch | The epoch of partition. The system assigns the version epoch when the partition was created, and changes it when the partition was swapped. |
| VersionTxnType | The type of the transaction that generates the current data version. Valid values: NORMAL(normal transaction) andREPLICATION(data replication). |
Display information of all regular partitions from the specified table site_accessunder the specified databasetest.MySQL > show partitions from test.site_access\G
 PartitionId: 20990
 PartitionName: p2019
 VisibleVersion: 1
 VisibleVersionHash: 0
 State: NORMAL
 PartitionKey: datekey
 DistributionKey: site_id
 Buckets: 6
 ReplicationNum: 3
 StorageMedium: HDD
 DataSize: 4KB
 IsInMemory: false
 RowCount: 3
Display information of all temporary partitions from the specified table site_accessunder the specified databasetest.SHOW TEMPORARY PARTITIONS FROM test.site_access;
Display the information of the specified partition p1of the specified tablesite_accessunder the specified databasetest.-- Regular partition
 -- Temporary partition
 SHOW TEMPORARY PARTITIONS FROM test.site_access WHERE PartitionName = "p1";
Display the latest partition information of the specified table site_accessunder the specified databasetest.-- Regular partition
