SHOW CREATE TABLE
Returns the CREATE TABLE statement that was used to create a given table.
In versions earlier than v3.0, the SHOW CREATE TABLE statement requires you to have the
SELECT_PRIVprivilege on the table. Since v3.0, the SHOW CREATE TABLE statement requires you to have theSELECTprivilege on the table.
Since v3.0, you can use the SHOW CREATE TABLE statement to view the CREATE TABLE statements of the tables that are managed by an external catalog and are stored in Apache Hiveβ’, Apache Iceberg, Apache Hudi, or Delta Lake.
Since v2.5.7, StarRocks can automatically set the number of buckets (BUCKETS) when you create a table or add a partition. You no longer need to manually set the number of buckets. For detailed information, see set the number of buckets.
- If you specified the number of buckets when creating a table, the output of SHOW CREATE TABLE will display the number of buckets.
- If you did not specify the number of buckets when creating a table, the output of SHOW CREATE TABLE will not display the number of buckets. You can run SHOW PARTITIONS to view the number of buckets for each partition.
In versions earlier than v2.5.7, you are required to set the number of buckets when creating a table. Therefore, SHOW CREATE TABLE displays the number of buckets by default.
SHOW CREATE TABLE [db_name.]table_name
Parametersβ
| db_name | No | The database name. If this parameter is not specified, the CREATE TABLE statement of a given table in your current database is returned by default. |
| table_name | Yes | The table name. |
Outputβ
| Table     | Create Table   |
The following table describes the parameters returned by this statement.
| Parameter | Description |
| Table | The table name. |
| Create Table | The CREATE TABLE statement of the table. |
Bucket number is not specifiedβ
Create a table named example_table with no bucket number specified in DISTRIBUTED BY.
CREATE TABLE example_table
    k1 TINYINT,
    v1 CHAR(10) REPLACE,
    v2 INT SUM
ENGINE = olap
AGGREGATE KEY(k1, k2)
DISTRIBUTED BY HASH(k1);
Run SHOW CREATE TABLE to display the CREATE TABLE statement of example_table. No bucket number is displayed in DISTRIBUTED BY. Note that if you did not specify PROPERTIES when you create the table, the default properties are displayed in the output of SHOW CREATE TABLE.
SHOW CREATE TABLE example_table\G
       Table: example_table
Create Table: CREATE TABLE `example_table` (
  `k1` tinyint(4) NULL COMMENT "",
  `k2` decimal64(10, 2) NULL DEFAULT "10.5" COMMENT "",
  `v1` char(10) REPLACE NULL COMMENT "",
  `v2` int(11) SUM NULL COMMENT ""
AGGREGATE KEY(`k1`, `k2`)
DISTRIBUTED BY HASH(`k1`)
"in_memory" = "false",
"compression" = "LZ4"
Bucket number is specifiedβ
Create a table named example_table1 with bucket number set to 10 in DISTRIBUTED BY.
CREATE TABLE example_table1
    k1 TINYINT,
    v2 INT SUM
ENGINE = olap
DISTRIBUTED BY HASH(k1) BUCKETS 10;
Run SHOW CREATE TABLE to display the CREATE TABLE statement of example_table. The bucket number (BUCKETS 10) is displayed in DISTRIBUTED BY. Note that if you did not specify PROPERTIES when you create the table, the default properties are displayed in the output of SHOW CREATE TABLE.
SHOW CREATE TABLE example_table1\G
       Table: example_table1
Create Table: CREATE TABLE `example_table1` (
DISTRIBUTED BY HASH(`k1`) BUCKETS 10
