Version: Candidate-4.0
REFRESH EXTERNAL TABLE
REFRESH EXTERNAL TABLE metadata cached in StarRocks. The metadata is from tables in data lakes. This statement is used in the following scenarios:
  • External table: When using a Hive external table or Hudi external table to query data in Apache Hiveβ„’ or Apache Hudi, you can execute this statement to update the metadata of a Hive table or Hudi table cached in StarRocks.
  • External catalog: When using an external catalog to query data in the corresponding data source, you can execute this statement to update the metadata cached in StarRocks.
Only users with the ALTER privilege on the corresponding external table can perform this operation.
Basic concepts​
  • Hive external table: is created and stored in StarRocks. You can use it to query Hive data.
  • Hudi external table: is created and stored in StarRocks. You can use it to query Hudi data.
  • Hive table: is created and stored in Hive.
  • Hudi table: is created and stored in Hudi.
Syntaxes and parameters​
The following describes the syntaxes and parameters based on different cases:
  • External table
    REFRESH EXTERNAL TABLE table_name
    [PARTITION ('partition_name', ...)]
    ParameterRequiredDescription
    table_nameYesThe name of a Hive external table or Hudi external table.
    partition_nameNoThe names of the partitions of a Hive table or Hudi table. Specifying this parameter updates the metadata of the partitions of the Hive table and Hudi table cached in StarRocks.
  • External catalog
    REFRESH EXTERNAL TABLE [external_catalog.][db_name.]table_name
    external_catalogNoThe name of the external catalog, which supports Hive, Hudi, Delta Lake, and MaxCompute (since v3.3) catalogs.
    db_nameNoThe name of the database where the destination table resides.
    table_nameYesThe name of the table.
    partition_nameNoThe names of the partitions. Specifying this parameter updates the metadata of the partitions of the destination table cached in StarRocks.
Usage notes​
Only users who have the ALTER_PRIV privilege can execute this statement to update the metadata of Hive tables and Hudi tables cached in StarRocks.
Usage examples in different cases are as follows:
External table​
Example 1: Update the cached metadata of the corresponding Hive table in StarRocks by specifying the external table hive1.
REFRESH EXTERNAL TABLE hive1;
Example 2: Update the cached metadata of the partitions of the corresponding Hudi table in StarRocks by specifying the external table hudi1 and the partitions in that table.
REFRESH EXTERNAL TABLE hudi1
PARTITION ('date=2022-12-20', 'date=2022-12-21');
External catalog​
Example 1: Update the metadata of hive_table cached in StarRocks.
Or
USE hive_catalog.hive_db;
Example 2: Update the metadata of the second-level partition p2 in hive_table cached in StarRocks.
Example 3: Update the metadata of the partitions of hudi_table cached in StarRocks.
