CREATE INDEX
Creates indexes.
You can create the following indexes:
For detailed instructions and examples on creating these indexes, see the corresponding tutorials listed above.
tip
This operation requires the ALTER privilege on the target table. You can follow the instructions in GRANT to grant this privilege.
CREATE INDEX index_name ON table_name (column_name)
[USING { BITMAP | NGRAMBF | GIN | VECTOR } ]
[(index_property)]
[COMMENT '<comment>']
Parameterβ
| index_name | Yes | The index name. For naming conventions, see System Limits. |
| table_name | Yes | The name of the table. |
| column_name | Yes | The name of the column to build index on. One column can have only one index. If a column already has an index, you cannot create one more index on it. |
| USING | No | The type of the index to create. Valid values:
| index_property | No | The properties of the index to create. For NGRAMBF,GIN, andVECTOR, you must specify the corresponding properties. For detailed instructions, see the corresponding tutorials. |
| COMMENT | No | The comment for the index. |
Create a table sales_records as follows:
CREATE TABLE sales_records
    record_id int,
    seller_id int,
    item_id int
DISTRIBUTED BY hash(record_id)
    "replication_num" = "3"
Create a bitmap index index on the item_id column of sales_recordsγ
CREATE INDEX index ON sales_records (item_id) USING BITMAP COMMENT '';
