CANCEL ALTER TABLE
CANCEL ALTER TABLE cancels the execution of the ongoing ALTER TABLE operation, including:
- Modify columns.
- Optimize table schema (from v3.2), including modifying the bucketing method and the number of buckets.
- Create and delete the rollup index.
NOTICE
- This statement is a synchronous operation.
- This statement requires you to have the
ALTER_PRIVprivilege on the table.- This statement only supports canceling asynchronous operations using ALTER TABLE (as mentioned above) and does not support canceling synchronous operations using ALTER TABLE, such as rename.
CANCEL ALTER TABLE { COLUMN | OPTIMIZE | ROLLUP } FROM [db_name.]table_name
Parametersβ
{COLUMN ο½ OPTIMIZE | ROLLUP}- If COLUMNis specified, this statement cancels operations of modifying columns.
- If OPTIMIZEis specified, this statement cancels operations of optimizing table schema.
- If ROLLUPis specified, this statement cancels operations of adding or deleting the rollup index.
- If
db_name: optional. The name of the database to which the table belongs. If this parameter is not specified, your current database is used by default.
table_name: required. The table name.
Cancel the operation of modifying columns for example_tablein the databaseexample_db.CANCEL ALTER TABLE COLUMN FROM example_db.example_table;
Cancel the operation of optimizing table schema for example_tablein the databaseexample_db.CANCEL ALTER TABLE OPTIMIZE FROM example_db.example_table;
Cancel the operation of adding or deleting the rollup index for example_tablein the current database.CANCEL ALTER TABLE ROLLUP FROM example_table;
