SHOW MATERIALIZED VIEWS
SHOW MATERIALIZED VIEWS shows all or one specific asynchronous materialized view.
Since v3.0, the name of this statement is changed from SHOW MATERIALIZED VIEW to SHOW MATERIALIZED VIEWS.
tip
This operation does not require privileges.
[FROM db_name]
note
Since v3.3, SHOW MATERIALIZED VIEWS command will track the state of all task_runs if a refresh task consists of multiple partitions/task_runs to refresh. Only when all task_runs are success, last_refresh_state will return SUCCESS.
Parametersβ
| db_name | no | The name of the database to which the materialized view resides. If this parameter is not specified, the current database is used by default. |
| mv_name | no | The name of the materialized view to show. |
| mv_name_matcher | no | The matcher used to filter materialized views. |
Returnsβ
| Return | Description |
| id | The ID of the materialized view. |
| database_name | The name of the database in which the materialized view resides. |
| name | The name of the materialized view. |
| refresh_type | The refresh type of the materialized view, including ROLLUP, MANUAL, ASYNC, and INCREMENTAL. |
| is_active | Whether the materialized view state is active. Valid Value: trueandfalse. |
| partition_type | The partition type of the materialized view, including RANGE and UNPARTITIONED. |
| task_id | ID of the materialized view refresh task. |
| task_name | Name of the materialized view refresh task. |
| last_refresh_start_time | The start time of the last refresh of the materialized view. |
| last_refresh_finished_time | The end time of the last refresh of the materialized view. |
| last_refresh_duration | The time taken by the last refresh. Unit: seconds. |
| last_refresh_state | The status of the last refresh, including PENDING, RUNNING, FAILED, and SUCCESS. |
| last_refresh_force_refresh | Whether the last refresh is a FORCE refresh. |
| last_refresh_start_partition | The start partition of the last refresh in the materialized view. |
| last_refresh_end_partition | The end partition of the last refresh in the materialized view. |
| last_refresh_base_refresh_partitions | The base table partitions that were refreshed in the last refresh. |
| last_refresh_mv_refresh_partitions | The materialized view partitions that were refreshed in the last refresh. |
| last_refresh_error_code | The error code for the last failed refresh of the materialized view (if the materialized view state is not active). |
| last_refresh_error_message | The reason why the last refresh failed (if the materialized view state is not active). |
| rows | The number of data rows in the materialized view. |
| text | The statement used to create the materialized view. |
The following examples is based on this business scenario:
-- Create Table: customer
CREATE TABLE customer ( C_CUSTKEY     INTEGER NOT NULL,
                        C_NAME        VARCHAR(25) NOT NULL,
                        C_ADDRESS     VARCHAR(40) NOT NULL,
                        C_NATIONKEY   INTEGER NOT NULL,
                        C_PHONE       CHAR(15) NOT NULL,
                        C_ACCTBAL     double   NOT NULL,
                        C_MKTSEGMENT  CHAR(10) NOT NULL,
                        C_COMMENT     VARCHAR(117) NOT NULL,
                        PAD char(1) NOT NULL)
    ENGINE=OLAP
DUPLICATE KEY(`c_custkey`)
DISTRIBUTED BY HASH(`c_custkey`)
"storage_format" = "DEFAULT"
-- Create MV: customer_mv
REFRESH MANUAL
AS SELECT
   FROM
              customer
-- Refresh the MV
Example 1: Show a specific materialized view.
mysql> SHOW MATERIALIZED VIEWS WHERE NAME='customer_mv'\G
             database_name: test
              refresh_type: MANUAL
                 is_active: true
     last_refresh_duration: 0
        last_refresh_state: SUCCESS
             inactive_code: 0
           inactive_reason:
COMMENT "MATERIALIZED_VIEW"
REFRESH MANUAL
"storage_medium" = "HDD"
FROM `test`.`customer`
                      rows: 0
1 row in set (0.11 sec)
Example 2: Show materialized views by matching the name.
mysql> SHOW MATERIALIZED VIEWS WHERE NAME LIKE 'customer_mv'\G
             database_name: test
                 is_active: true
             inactive_code: 0
           inactive_reason:
REFRESH MANUAL
                      rows: 0
1 row in set (0.12 sec)
