SHOW CREATE MATERIALIZED VIEW
SHOW CREATE MATERIALIZED VIEW shows the definition of a specific asynchronous materialized view.
tip
This operation does not require privileges.
SHOW CREATE MATERIALIZED VIEW [database.]<mv_name>
Parameters in brackets [] is optional.
Parametersβ
| mv_name | yes | The name of the materialized view to show. |
Returnsβ
| Return | Description |
| Materialized View | The name of the materialized view. |
| Create Materialized View | The definition of the materialized view. |
Example 1: Show the definition of a specific materialized view
MySQL > SHOW CREATE MATERIALIZED VIEW lo_mv1\G
       Materialized View: lo_mv1
Create Materialized View: CREATE MATERIALIZED VIEW `lo_mv1`
COMMENT "MATERIALIZED_VIEW"
DISTRIBUTED BY HASH(`lo_orderkey`)
REFRESH ASYNC
"storage_medium" = "HDD"
AS SELECT `wlc_test`.`lineorder`.`lo_orderkey` AS `lo_orderkey`, `wlc_test`.`lineorder`.`lo_custkey` AS `lo_custkey`, sum(`wlc_test`.`lineorder`.`lo_quantity`) AS `total_quantity`, sum(`wlc_test`.`lineorder`.`lo_revenue`) AS `total_revenue`, count(`wlc_test`.`lineorder`.`lo_shipmode`) AS `shipmode_count` FROM `wlc_test`.`lineorder` GROUP BY `wlc_test`.`lineorder`.`lo_orderkey`, `wlc_test`.`lineorder`.`lo_custkey` ORDER BY `wlc_test`.`lineorder`.`lo_orderkey` ASC ;
