SHOW ALTER MATERIALIZED VIEW
SHOW ALTER MATERIALIZED VIEW shows the building status of synchronous materialized views.
tip
This operation does not require privileges.
SHOW ALTER MATERIALIZED VIEW [ { FROM | IN } db_name]
Parameters in brackets [] is optional.
Parametersβ
| db_name | no | The name of the database to which the materialized view resides. If this parameter is not specified, the current database is used by default. |
Returnsβ
| Return | Description |
| JobId | The ID of refresh job. |
| TableName | The name of the table. |
| CreateTime | The time when refresh job is created. |
| FinishedTime | The time when refresh job is finished. |
| BaseIndexName | The name of the base table. |
| RollupIndexName | The name of the materialized view. |
| RollupId | The ID of the materialized view rollup. |
| TransactionId | The ID of transaction that waits to be executed. |
| State | The state of the job. |
| Msg | Error message. |
| Progress | Progress of the refresh job. |
| Timeout | Timeout for the refresh job. |
Example 1: building status of synchronous materialized views
MySQL > SHOW ALTER MATERIALIZED VIEW\G
          JobId: 475991
      TableName: lineorder
     CreateTime: 2022-08-24 19:46:53
   FinishedTime: 2022-08-24 19:47:15
  BaseIndexName: lineorder
RollupIndexName: lo_mv_sync_1
       RollupId: 475992
  TransactionId: 33067
          State: FINISHED
            Msg:
       Progress: NULL
        Timeout: 86400
          JobId: 477337
     CreateTime: 2022-08-24 19:47:25
   FinishedTime: 2022-08-24 19:47:45
RollupIndexName: lo_mv_sync_2
       RollupId: 477338
  TransactionId: 33068
          State: FINISHED
            Msg:
       Progress: NULL
        Timeout: 86400
2 rows in set (0.00 sec)
