STREAM LOAD
StarRocks provides the loading method HTTP-based STREAM LOAD to help you load data from a local file system or a streaming data source. After you submit a load job, StarRocks synchronously runs the job, and returns the result of the job after the job finishes. You can determine whether the job is successful based on the job result. For information about the application scenarios, limits, principles, and supported data file formats of Stream Load, see Loading from a local file system via Stream Load.
This example uses the Local Climatological Data(LCD) dataset featured in the StarRocks Basics Quick Start. You can load the data and try the example yourself.
Since v3.2.7, Stream Load supports compressing JSON data during transmission, reducing network bandwidth overhead. Users can specify different compression algorithms using parameters compression and Content-Encoding. Supported compression algorithms including GZIP, BZIP2, LZ4_FRAME, and ZSTD. For more information, see data_desc.
From v3.4.0, the system supports merging multiple Stream Load requests. For more information, see Merge Commit parameters.
NOTICE
- After you load data into a StarRocks table by using Stream Load, the data of the materialized views that are created on that table is also updated.
- You can load data into StarRocks tables only as a user who has the INSERT privilege on those StarRocks tables. If you do not have the INSERT privilege, follow the instructions provided in GRANT to grant the INSERT privilege to the user that you use to connect to your StarRocks cluster.
curl --location-trusted -u <username>:<password> -XPUT <url>
    data_desc
[opt_properties]
This topic uses curl as an example to describe how to load data by using Stream Load. In addition to curl, you can also use other HTTP-compatible tools or languages to perform Stream Load. Load-related parameters are included in HTTP request header fields. When you input these parameters, take note of the following points:
You can use chunked transfer encoding, as demonstrated in this topic. If you do not choose chunked transfer encoding, you must input a Content-Lengthheader field to indicate the length of content to be transferred, thereby ensuring data integrity.NOTE If you use curl to perform Stream Load, StarRocks automatically adds a Content-Lengthheader field and you do not need manually input it.
You must add an Expectheader field and specify its value as100-continue, as in"Expect:100-continue". This helps prevent unnecessary data transfers and reduce resource overheads in case your job request is denied.
Note that in StarRocks some literals are used as reserved keywords by the SQL language. Do not directly use these keywords in SQL statements. If you want to use such a keyword in an SQL statement, enclose it in a pair of backticks (`). See Keywords.
Parametersβ
username and passwordβ
Specify the username and password of the account that you use to connect to your StarRocks cluster. This is a required parameter. If you use an account for which no password is set, you need to input only <username>:.
XPUTβ
Specifies the HTTP request method. This is a required parameter. Stream Load supports only the PUT method.
urlβ
Specifies the URL of the StarRocks table. Syntax:
The following table describes the parameters in the URL.
| fe_host | Yes | The IP address of the FE node in your StarRocks cluster. NOTE If you submit the load job to a specific BE or CN node, you must input the IP address of the BE or CN node. |
| fe_http_port | Yes | The HTTP port number of the FE node in your StarRocks cluster. The default port number is 8030.NOTE If you submit the load job to a specific BE or CN node, you must input the HTTP port number of the BE or CN node. The default port number is 8030. |
| database_name | Yes | The name of the database to which the StarRocks table belongs. |
| table_name | Yes | The name of the StarRocks table. |
You can use SHOW FRONTENDS to view the IP address and HTTP port of the FE node.
data_descβ
Describes the data file that you want to load. The data_desc descriptor can include the data file's name, format, column separator, row separator, destination partitions, and column mapping against the StarRocks table. Syntax:
-T <file_path>
-H "format: CSV | JSON"
-H "column_separator: <column_separator>"
-H "row_delimiter: <row_delimiter>"
-H "columns: <column1_name>[, <column2_name>, ... ]"
-H "partitions: <partition1_name>[, <partition2_name>, ...]"
-H "temporary_partitions: <temporary_partition1_name>[, <temporary_partition2_name>, ...]"
-H "jsonpaths: [ \"<json_path1>\"[, \"<json_path2>\", ...] ]"
-H "strip_outer_array: true | false"
-H "json_root: <json_path>"
-H "ignore_json_size: true | false"
-H "compression: <compression_algorithm> | Content-Encoding: <compression_algorithm>"
The parameters in the data_desc descriptor can be divided into three types: common parameters, CSV parameters, and JSON parameters.
Common parametersβ
| file_path | Yes | The save path of the data file. You can optionally include the extension of the file name. |
| format | No | The format of the data file. Valid values: CSVandJSON. Default value:CSV. |
| partitions | No | The partitions into which you want to load the data file. By default, if you do not specify this parameter, StarRocks loads the data file into all partitions of the StarRocks table. |
| temporary_partitions | No | The name of the temporary partition into which you want to load data file. You can specify multiple temporary partitions, which must be separated by commas (,). |
| columns | No | The column mapping between the data file and the StarRocks table. If the fields in the data file can be mapped in sequence onto the columns in the StarRocks table, you do not need to specify this parameter. Instead, you can use this parameter to implement data conversions. For example, if you load a CSV data file and the file consists of two columns that can be mapped in sequence onto the two columns, idandcity, of the StarRocks table, you can specify"columns: city,tmp_id, id = tmp_id * 100". For more information, see the "Column mapping" section in this topic. |
CSV parametersβ
| column_separator | No | The characters that are used in the data file to separate fields. If you do not specify this parameter, this parameter defaults to \t, which indicates tab.Make sure that the column separator you specify by using this parameter is the same as the column separator used in the data file. NOTE - For CSV data, you can use a UTF-8 string, such as a comma (,), tab, or pipe (|), whose length does not exceed 50 bytes as a text delimiter. - If the data file uses consecutive non-printable characters (for example, \r\n) as the column separator, you must set this parameter as\\x0D0A. |
| row_delimiter | No | The characters that are used in the data file to separate rows. If you do not specify this parameter, this parameter defaults to \n.NOTE If the data file uses consecutive non-printable characters (for example, \r\n) as the row delimiter, you must set this parameter as\\x0D0A. |
| skip_header | No | Specifies whether to skip the first few rows of the data file when the data file is in CSV format. Type: INTEGER. Default value: 0.In some CSV-formatted data files, the first few rows at the beginning are used to define metadata such as column names and column data types. By setting the skip_headerparameter, you can enable StarRocks to skip the first few rows of the data file during data loading. For example, if you set this parameter to1, StarRocks skips the first row of the data file during data loading.The first few rows at the beginning in the data file must be separated by using the row separator that you specify in the load command. |
| trim_space | No | Specifies whether to remove spaces preceding and following column separators from the data file when the data file is in CSV format. Type: BOOLEAN. Default value: false.For some databases, spaces are added to column separators when you export data as a CSV-formatted data file. Such spaces are called leading spaces or trailing spaces depending on their locations. By setting the trim_spaceparameter, you can enable StarRocks to remove such unnecessary spaces during data loading.Note that StarRocks does not remove the spaces (including leading spaces and trailing spaces) within a field wrapped in a pair of enclose-specified characters. For example, the following field values use pipe (|) as the column separator and double quotation marks (") as theenclose-specified character:|"Love StarRocks"||" Love StarRocks "|| "Love StarRocks" |If you set trim_spacetotrue, StarRocks processes the preceding field values as follows:|"Love StarRocks"||" Love StarRocks "||"Love StarRocks"| |
| enclose | No | Specifies the character that is used to wrap the field values in the data file according to RFC4180 when the data file is in CSV format. Type: single-byte character. Default value: NONE. The most prevalent characters are single quotation mark (') and double quotation mark (").All special characters (including row separators and column separators) wrapped by using the enclose-specified character are considered normal symbols. StarRocks can do more than RFC4180 as it allows you to specify any single-byte character as theenclose-specified character.If a field value contains an enclose-specified character, you can use the same character to escape thatenclose-specified character. For example, you setencloseto", and a field value isa "quoted" c. In this case, you can enter the field value as"a ""quoted"" c"into the data file. |
| escape | No | Specifies the character that is used to escape various special characters, such as row separators, column separators, escape characters, and enclose-specified characters, which are then considered by StarRocks to be common characters and are parsed as part of the field values in which they reside. Type: single-byte character. Default value:NONE. The most prevalent character is slash (\), which must be written as double slashes (\\) in SQL statements.NOTE The character specified by escapeis applied to both inside and outside of each pair ofenclose-specified characters.Two examples are as follows:
- Null values are denoted by using
\N. For example, a data file consists of three columns, and a record from that data file holds data in the first and third columns but no data in the second column. In this situation, you need to use\Nin the second column to denote a null value. This means the record must be compiled asa,\N,binstead ofa,,b.a,,bdenotes that the second column of the record holds an empty string.- The format options, including
skip_header,trim_space,enclose, andescape, are supported in v3.0 and later.
JSON parametersβ
| jsonpaths | No | The names of the keys that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is in JSON format. See Configure column mapping for JSON data loading. |
| strip_outer_array | No | Specifies whether to strip the outermost array structure. Valid values: trueandfalse. Default value:false.In real-world business scenarios, the JSON data may have an outermost array structure as indicated by a pair of square brackets []. In this situation, we recommend that you set this parameter totrue, so StarRocks removes the outermost square brackets[]and loads each inner array as a separate data record. If you set this parameter tofalse, StarRocks parses the entire JSON data file into one array and loads the array as a single data record.For example, the JSON data is [ {"category" : 1, "author" : 2}, {"category" : 3, "author" : 4} ]. If you set this parameter totrue,{"category" : 1, "author" : 2}and{"category" : 3, "author" : 4}are parsed into separate data records that are loaded into separate StarRocks table rows. |
| json_root | No | The root element of the JSON data that you want to load from the JSON data file. You need to specify this parameter only when you load JSON data by using the matched mode. The value of this parameter is a valid JsonPath string. By default, the value of this parameter is empty, indicating that all data of the JSON data file will be loaded. For more information, see the "Load JSON data using matched mode with root element specified" section of this topic. |
| ignore_json_size | No | Specifies whether to check the size of the JSON body in the HTTP request. NOTE By default, the size of the JSON body in an HTTP request cannot exceed 100 MB. If the JSON body exceeds 100 MB in size, an error "The size of this batch exceed the max size [104857600] of json type data data [8617627793]. Set ignore_json_size to skip check, although it may lead huge memory consuming." is reported. To prevent this error, you can add "ignore_json_size:true"in the HTTP request header to instruct StarRocks not to check the JSON body size. |
| compression, Content-Encoding | NO | The encoding algorithm that is applied to the data during transmission. Supported algorithms include GZIP, BZIP2, LZ4_FRAME, and ZSTD. Example: curl --location-trusted -u root:  -v 'http://127.0.0.1:18030/api/db0/tbl_simple/_stream_load' \-X PUT  -H "expect:100-continue" \-H 'format: json' -H 'compression: lz4_frame'   -T ./b.json.lz4. |
When you load JSON data, also note that the size per JSON object cannot exceed 4 GB. If an individual JSON object in the JSON data file exceeds 4 GB in size, an error "This parser can't support a document that big." is reported.
Merge Commit parametersβ
Enables Merge Commit for multiple concurrent Stream Load requests within a specified time window and to merge them into a single transaction.
| enable_merge_commit | No | Whether to enable the Merge Commit for the loading request. Valid values: trueandfalse(Default). |
| merge_commit_async | No | The server's return mode. Valid values:
| merge_commit_interval_ms | Yes | The size of the merging time window. Unit: milliseconds. Merge Commit attempts to merge loading requests received within this window into a single transaction. A larger window improves merging efficiency but increases latency. |
| merge_commit_parallel | Yes | The degree of parallelism for the loading plan created for each merging window. Parallelism can be adjusted based on the load of ingestion. Increase this value if there are many requests and/or a large amount of data to load. The parallelism is limited to the number of BE nodes, calculated as max(merge_commit_parallel, number of BE nodes). |
- Merge Commit only supports merging homogeneous loading requests into a single database and table. "Homogeneous" indicates that the Stream Load parameters are identical, including: common parameters, JSON format parameters, CSV format parameters, opt_properties, and Merge Commit parameters.
- For loading CSV-formatted data, you must ensure that each row ends with a line separator. skip_headeris not supported.
- The server automatically generates labels for transactions. They will be ignored if specified.
- Merge Commit merges multiple loading requests into a single transaction. If one request contains data quality issues, all requests in the transaction will fail.
opt_propertiesβ
Specifies some optional parameters, which are applied to the entire load job. Syntax:
-H "label: <label_name>"
-H "where: <condition1>[, <condition2>, ...]"
-H "max_filter_ratio: <num>"
-H "timeout: <num>"
-H "strict_mode: true | false"
-H "timezone: <string>"
-H "load_mem_limit: <num>"
-H "partial_update: true | false"
-H "partial_update_mode: row | column"
-H "merge_condition: <column_name>"
The following table describes the optional parameters.
| label | No | The label of the load job. If you do not specify this parameter, StarRocks automatically generates a label for the load job. StarRocks does not allow you to use one label to load a data batch multiple times. As such, StarRocks prevents the same data from being repeatedly loaded. For label naming conventions, see System limits. By default, StarRocks retains the labels of load jobs that were successfully completed over the most recent three days. You can use the FE parameter label_keep_max_secondto change the label retention period. |
| where | No | The conditions based on which StarRocks filters the pre-processed data. StarRocks loads only the pre-processed data that meets the filter conditions specified in the WHERE clause. |
| max_filter_ratio | No | The maximum error tolerance of the load job. The error tolerance is the maximum percentage of data records that can be filtered out due to inadequate data quality in all data records requested by the load job. Valid values: 0to1. Default value:0.We recommend that you retain the default value 0. This way, if unqualified data records are detected, the load job fails, thereby ensuring data correctness.If you want to ignore unqualified data records, you can set this parameter to a value greater than 0. This way, the load job can succeed even if the data file contains unqualified data records.NOTE Unqualified data records do not include data records that are filtered out by the WHERE clause. |
| log_rejected_record_num | No | Specifies the maximum number of unqualified data rows that can be logged. This parameter is supported from v3.1 onwards. Valid values: 0,-1, and any non-zero positive integer. Default value:0.
| timeout | No | The timeout period of the load job. Valid values: 1to259200. Unit: second. Default value:600.NOTEIn addition to the timeoutparameter, you can also use the FE parameterstream_load_default_timeout_secondto centrally control the timeout period for all Stream Load jobs in your StarRocks cluster. If you specify thetimeoutparameter, the timeout period specified by thetimeoutparameter prevails. If you do not specify thetimeoutparameter, the timeout period specified by thestream_load_default_timeout_secondparameter prevails. |
| strict_mode | No | Specifies whether to enable the strict mode. Valid values: trueandfalse. Default value:false.  The valuetruespecifies to enable the strict mode, and the valuefalsespecifies to disable the strict mode. |
| timezone | No | The time zone used by the load job. Default value: Asia/Shanghai. The value of this parameter affects the results returned by functions such as strftime, alignment_timestamp, and from_unixtime. The time zone specified by this parameter is a session-level time zone. For more information, see Configure a time zone. |
| load_mem_limit | No | The maximum amount of memory that can be provisioned to the load job. Unit: bytes. By default, the maximum memory size for a load job is 2 GB. The value of this parameter cannot exceed the maximum amount of memory that can be provisioned to each BE or CN. |
| partial_update | No | Whether to use partial updates. Valid values: TRUEandFALSE. Default value:FALSE, indicating to disable this feature. |
| partial_update_mode | No | Specifies the mode for partial updates. Valid values: rowandcolumn.
| merge_condition | No | Specifies the name of the column you want to use as the condition to determine whether updates can take effect. The update from a source record to a destination record takes effect only when the source data record has a greater or equal value than the destination data record in the specified column. StarRocks supports conditional updates since v2.5. NOTE The column that you specify cannot be a primary key column. Additionally, only tables that use the Primary Key table support conditional updates. |
Column mappingβ
Configure column mapping for CSV data loadingβ
If the columns of the data file can be mapped one on one in sequence to the columns of the StarRocks table, you do not need to configure the column mapping between the data file and the StarRocks table.
If the columns of the data file cannot be mapped one on one in sequence to the columns of the StarRocks table, you need to use the columns parameter to configure the column mapping between the data file and the StarRocks table. This includes the following two use cases:
Same number of columns but different column sequence. Also, the data from the data file does not need to be computed by functions before it is loaded into the matching StarRocks table columns. In the columnsparameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged.For example, the StarRocks table consists of three columns, which are col1,col2, andcol3in sequence, and the data file also consists of three columns, which can be mapped to the StarRocks table columnscol3,col2, andcol1in sequence. In this case, you need to specify"columns: col3, col2, col1".
Different number of columns and different column sequence. Also, the data from the data file needs to be computed by functions before it is loaded into the matching StarRocks table columns. In the columnsparameter, you need to specify the names of the StarRocks table columns in the same sequence as how the data file columns are arranged and specify the functions you want to use to compute the data. Two examples are as follows:- The StarRocks table consists of three columns, which are col1,col2, andcol3in sequence. The data file consists of four columns, among which the first three columns can be mapped in sequence to the StarRocks table columnscol1,col2, andcol3and the fourth column cannot be mapped to any of the StarRocks table columns. In this case, you need to temporarily specify a name for the fourth column of the data file, and the temporary name must be different from any of the StarRocks table column names. For example, you can specify"columns: col1, col2, col3, temp", in which the fourth column of the data file is temporarily namedtemp.
- The StarRocks table consists of three columns, which are year,month, anddayin sequence. The data file consists of only one column that accommodates date and time values inyyyy-mm-dd hh:mm:ssformat. In this case, you can specify"columns: col, year = year(col), month=month(col), day=day(col)", in whichcolis the temporary name of the data file column and the functionsyear = year(col),month=month(col), andday=day(col)are used to extract data from the data file columncoland loads the data into the mapping StarRocks table columns. For example,year = year(col)is used to extract theyyyydata from the data file columncoland loads the data into the StarRocks table columnyear.
For detailed examples, see Configure column mapping.
Configure column mapping for JSON data loadingβ
If the keys of the JSON document have the same names as the columns of the StarRocks table, you can load the JSON-formatted data by using the simple mode. In simple mode, you do not need to specify the jsonpaths parameter. This mode requires that the JSON-formatted data must be an object as indicated by curly brackets {}, such as {"category": 1, "author": 2, "price": "3"}. In this example, category, author, and price are key names, and these keys can be mapped one on one by name to the columns category, author, and price of the StarRocks table.
If the keys of the JSON document have different names than the columns of the StarRocks table, you can load the JSON-formatted data by using the matched mode. In matched mode, you need to use the jsonpaths and COLUMNS parameters to specify the column mapping between the JSON document and the StarRocks table:
- In the jsonpathsparameter, specify the JSON keys in the sequence as how they are arranged in the JSON document.
- In the COLUMNSparameter, specify the mapping between the JSON keys and the StarRocks table columns:- The column names specified in the COLUMNSparameter are mapped one on one in sequence to the JSON keys.
- The column names specified in the COLUMNSparameter are mapped one on one by name to the StarRocks table columns.
For examples about loading JSON-formatted data by using the matched mode, see Load JSON data using matched mode.
Return valueβ
After the load job finishes, StarRocks returns the job result in JSON format. Example:
    "TxnId": 1003,
    "Label": "label123",
    "Status": "Success",
    "Message": "OK",
    "NumberTotalRows": 1000000,
    "NumberLoadedRows": 999999,
    "NumberFilteredRows": 1,
    "NumberUnselectedRows": 0,
    "LoadBytes": 40888898,
    "LoadTimeMs": 2144,
    "BeginTxnTimeMs": 0,
    "StreamLoadPlanTimeMs": 1,
    "ReadDataTimeMs": 0,
    "WriteDataTimeMs": 11,
    "CommitAndPublishTimeMs": 16,
The following table describes the parameters in the returned job result.
| Parameter | Description |
| TxnId | The transaction ID of the load job. |
| Label | The label of the load job. |
| Status | The final status of the data loaded.
| Message | The status of the load job. If the load job fails, the detailed failure cause is returned. |
| NumberTotalRows | The total number of data records that are read. |
| NumberLoadedRows | The total number of data records that are successfully loaded. This parameter is valid only when the value returned for StatusisSuccess. |
| NumberFilteredRows | The number of data records that are filtered out due to inadequate data quality. |
| NumberUnselectedRows | The number of data records that are filtered out by the WHERE clause. |
| LoadBytes | The amount of data that is loaded. Unit: bytes. |
| LoadTimeMs | The amount of time that is taken by the load job. Unit: ms. |
| BeginTxnTimeMs | The amount of time that is taken to run a transaction for the load job. |
| StreamLoadPlanTimeMs | The amount of time that is taken to generate a execution plan for the load job. |
| ReadDataTimeMs | The amount of time that is taken to read data for the load job. |
| WriteDataTimeMs | The amount of time that is taken to write data for the load job. |
| CommitAndPublishTimeMs | The amount of time that is taken to commit and publish data for the load job. |
If the load job fails, StarRocks also returns ErrorURL. Example:
{"ErrorURL": "http://172.26.195.68:8045/api/_load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be"}
ErrorURL provides a URL from which you can obtain details about unqualified data records that have been filtered out. You can specify the maximum number of unqualified data rows that can be logged by using the optional parameter log_rejected_record_num, which is set when you submit a load job.
You can run curl "url" to directly view details about the filtered-out, unqualified data records. You can also run wget "url" to export the details about these data records:
wget http://172.26.195.68:8045/api/_load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be
The exported data record details are saved to a local file with a name similar to _load_error_log?file=error_log_3a4eb8421f0878a6_9a54df29fd9206be. You can use the cat command to view the file.
Then, you can adjust the configuration of the load job, and submit the load job again.
Load CSV dataβ
This section CSV data as an example to describe how you can employ various parameter settings and combinations to meet your diverse loading requirements.
Set timeout periodβ
Your StarRocks database test_db contains a table named table1. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example1.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table1.
If you want to load all data from example1.csv into table1 within up to 100 seconds, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label1" \
    -H "Expect:100-continue" \
    -H "timeout:100" \
    -H "max_filter_ratio:0.2" \
    -T example1.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table1/_stream_load
Set error toleranceβ
Your StarRocks database test_db contains a table named table2. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example2.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table2.
If you want to load all data from example2.csv into table2 with a maximum error tolerance of 0.2, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label2" \
    -T example2.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table2/_stream_load
Configure column mappingβ
Your StarRocks database test_db contains a table named table3. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example3.csv also consists of three columns, which can be mapped in sequence onto col2, col1, and col3 of table3.
If you want to load all data from example3.csv into table3, run the following command:
curl --location-trusted -u <username>:<password>  -H "label:label3" \
    -H "columns: col2, col1, col3" \
    -T example3.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table3/_stream_load
In the preceding example, the columns of
example3.csvcannot be mapped onto the columns oftable3in the same sequence as how these columns are arranged intable3. Therefore, you need to use thecolumnsparameter to configure the column mapping betweenexample3.csvandtable3.
Set filter conditionsβ
Your StarRocks database test_db contains a table named table4. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example4.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table4.
If you want to load only the data records whose values in the first column of example4.csv are equal to 20180601 into table4, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label4" \
    -H "columns: col1, col2, col3"\
    -H "where: col1 = 20180601" \
    -T example4.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table4/_stream_load
example4.csvandtable4have the same number of columns that can be mapped in sequence, but you need to use the WHERE clause to specify column-based filter conditions. Therefore, you need to use thecolumnsparameter to define temporary names for the columns ofexample4.csv.
Set destination partitionsβ
Your StarRocks database test_db contains a table named table5. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example5.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table5.
If you want to load all data from example5.csv into partitions p1 and p2 of table5, run the following command:
curl --location-trusted -u <username>:<password>  -H "label:label5" \
    -H "partitions: p1, p2" \
    -T example5.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table5/_stream_load
Set strict mode and time zoneβ
Your StarRocks database test_db contains a table named table6. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example6.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table6.
If you want to load all data from example6.csv into table6 by using the strict mode and the time zone Africa/Abidjan, run the following command:
    -H "strict_mode: true" \
    -H "timezone: Africa/Abidjan" \
    -T example6.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table6/_stream_load
Load data into tables containing HLL-type columnsβ
Your StarRocks database test_db contains a table named table7. The table consists of two HLL-type columns, which are col1 and col2 in sequence.
Your data file example7.csv also consists of two columns, among which the first column can be mapped onto col1 of table7 and the second column cannot be mapped onto any column of table7. The values in the first column of example7.csv can be converted into HLL-type data by using functions before they are loaded into col1 of table7.
If you want to load data from example7.csv into table7, run the following command:
    -T example7.csv -XPUT \
In the preceding example, the two columns of
example7.csvare namedtemp1andtemp2in sequence by using thecolumnsparameter. Then, functions are used to convert data as follows:
The
hll_hashfunction is used to convert the values intemp1ofexample7.csvinto HLL-type data and maptemp1ofexample7.csvontocol1oftable7.
The
hll_emptyfunction is used to fill the specified default value intocol2oftable7.
For usage of the functions hll_hash and hll_empty, see hll_hash and hll_empty.
Load data into tables containing BITMAP-type columnsβ
Your StarRocks database test_db contains a table named table8. The table consists of two BITMAP-type columns, which are col1 and col2, in sequence.
Your data file example8.csv also consists of two columns, among which the first column can be mapped onto col1 of table8 and the second column cannot be mapped onto any column of table8. The values in the first column of example8.csv can be converted by using functions before they are loaded into col1 of table8.
If you want to load data from example8.csv into table8, run the following command:
    -H "columns: temp1, temp2, col1=to_bitmap(temp1), col2=bitmap_empty()" \
    -T example8.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table8/_stream_load
example8.csvare namedtemp1andtemp2in sequence by using thecolumnsparameter. Then, functions are used to convert data as follows:
The
to_bitmapfunction is used to convert the values intemp1ofexample8.csvinto BITMAP-type data and maptemp1ofexample8.csvontocol1oftable8.
The
bitmap_emptyfunction is used to fill the specified default value intocol2oftable8.
For usage of the functions to_bitmap and bitmap_empty, see to_bitmap and bitmap_empty.
Setting skip_header, trim_space, enclose, and escapeβ
Your StarRocks database test_db contains a table named table9. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example9.csv also consists of three columns, which are mapped in sequence onto col2, col1, and col3 of table13.
If you want to load all data from example9.csv into table9, with the intention of skipping the first five rows of example9.csv, removing the spaces preceding and following column separators, and setting enclose to \ and escape to \, run the following command:
curl --location-trusted -u <username>:<password> -H "label:3875" \
    -H "trim_space: true" -H "skip_header: 5" \
    -H "column_separator:," -H "enclose:\"" -H "escape:\\" \
    -T example9.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/tbl9/_stream_load
Set column_separator and row_delimiterβ
Your StarRocks database test_db contains a table named table10. The table consists of three columns, which are col1, col2, and col3 in sequence.
Your data file example10.csv also consists of three columns, which can be mapped in sequence onto col1, col2, and col3 of table10. The columns in a data row are separated by commas (,), and data rows are separated by two consecutive non-printable characters \r\n.
If you want to load all data from example10.csv into table10, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label10" \
    -H "column_separator:," \
    -H "row_delimiter:\\x0D0A" \
    -T example10.csv -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/table10/_stream_load
Load JSON dataβ
This section describes the parameter settings that you need to take note of when you load JSON data.
Your StarRocks database test_db contains a table named tbl1, whose schema is as follows:
`category` varchar(512) NULL COMMENT "",`author` varchar(512) NULL COMMENT "",`title` varchar(512) NULL COMMENT "",`price` double NULL COMMENT ""
Load JSON data using simple modeβ
Suppose that your data file example1.json consists of the following data:
To load all data from example1.json into tbl1, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label6" \
    -H "format: json" \
    -T example1.json -XPUT \
    http://<fe_host>:<fe_http_port>/api/test_db/tbl1/_stream_load
In the preceding example, the parameters
columnsandjsonpathsare not specified. Therefore, the keys inexample1.jsonare mapped by name onto the columns oftbl1.
To increase throughput, Stream Load supports loading multiple data records all at once. Example:
[{"category":"C++","author":"avc","title":"C++ primer","price":89.5},{"category":"Java","author":"avc","title":"Effective Java","price":95},{"category":"Linux","author":"avc","title":"Linux kernel","price":195}]
Load JSON data using matched modeβ
StarRocks performs the following steps to match and process JSON data:
(Optional) Strips the outermost array structure as instructed by the strip_outer_arrayparameter setting.NOTE This step is performed only when the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets []. You need to setstrip_outer_arraytotrue.
(Optional) Matches the root element of the JSON data as instructed by the json_rootparameter setting.NOTE This step is performed only when the JSON data has a root element. You need to specify the root element by using the json_rootparameter.
Extracts the specified JSON data as instructed by the jsonpathsparameter setting.
Load JSON data using matched mode without root element specifiedβ
Suppose that your data file example2.json consists of the following data:
[{"category":"xuxb111","author":"1avc","title":"SayingsoftheCentury","price":895},{"category":"xuxb222","author":"2avc","title":"SayingsoftheCentury","price":895},{"category":"xuxb333","author":"3avc","title":"SayingsoftheCentury","price":895}]
To load only category, author, and price from example2.json, run the following command:
curl --location-trusted -u <username>:<password> -H "label:label7" \
    -H "format: json" \
    -H "strip_outer_array: true" \
    -H "jsonpaths: [\"$.category\",\"$.price\",\"$.author\"]" \
    -H "columns: category, price, author" \
    -T example2.json -XPUT \
In the preceding example, the outermost layer of the JSON data is an array structure as indicated by a pair of square brackets
[]. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to setstrip_outer_arraytotrueto strip the outermost array structure. The key title that you do not want to load is ignored during loading.
Load JSON data using matched mode with root element specifiedβ
Suppose your data file example3.json consists of the following data:
{"id": 10001,"RECORDS":[{"category":"11","title":"SayingsoftheCentury","price":895,"timestamp":1589191587},{"category":"22","author":"2avc","price":895,"timestamp":1589191487},{"category":"33","author":"3avc","title":"SayingsoftheCentury","timestamp":1589191387}],"comments": ["3 records", "there will be 3 rows"]}
To load only category, author, and price from example3.json, run the following command:
    -H "format: json" \
    -H "json_root: $.RECORDS" \
    -H "columns: category, price, author" -H "label:label8" \
    -T example3.json -XPUT \
[]. The array structure consists of multiple JSON objects that each represent a data record. Therefore, you need to setstrip_outer_arraytotrueto strip the outermost array structure. The keystitleandtimestampthat you do not want to load are ignored during loading. Additionally, thejson_rootparameter is used to specify the root element, which is an array, of the JSON data.
Merge Stream Load requestsβ
Run the following command to start a Stream Load job with Merge Commit enabled in synchronous mode, and set the merging window to 5000milliseconds and degree of parallelism to2:curl --location-trusted -u <username>:<password> \
 -H "columns: id, name, score" \
 -H "enable_merge_commit:true" \
 -H "merge_commit_interval_ms:5000" \
 -H "merge_commit_parallel:2" \
 http://<fe_host>:<fe_http_port>/api/mydatabase/table1/_stream_load
Run the following command to start a Stream Load job with Merge Commit enabled in asynchronous mode, and set the merging window to 60000milliseconds and degree of parallelism to2:curl --location-trusted -u <username>:<password> \
 -H "merge_commit_async:true" \
 -H "merge_commit_interval_ms:60000" \
