SHOW LOAD
SHOW LOAD displays information of all load jobs or given load jobs in a database. This statement can only display load jobs that are created by using Broker Load, INSERT, and SPARK_LOAD. You can also view load job information via the curl command. From v3.1 onwards, we recommend that you use the SELECT statement to query the results of Broker Load or Insert jobs from the loads table in the information_schema database. For more information, see Loading.
In addition to the preceding loading methods, StarRocks supports using Stream Load and Routine Load to load data. Stream Load is a synchronous operation and will directly return information of Stream Load jobs. Routine Load is an asynchronous operation where you can use the SHOW ROUTINE LOAD statement to display information of Routine Load jobs.
SHOW LOAD [ FROM db_name ]
   WHERE [ LABEL { = "label_name" | LIKE "label_matcher" } ]
         [ [AND] STATE = { "PENDING" | "ETL" | "LOADING" | "FINISHED" | "CANCELLED" } ]
[ ORDER BY field_name [ ASC | DESC ] ]
[ LIMIT { [offset, ] limit | limit OFFSET offset } ]
Note
You can add the
\Goption to the statement (such asSHOW LOAD WHERE LABEL = "label1"\G;) to vertically display output rather than in the usual horizontal table format. For more information, see Example 1.
Parametersβ
| db_name | No | The database name. If this parameter is not specified, your current database is used by default. |
| LABEL = "label_name" | No | The labels of load jobs. |
| LABEL LIKE "label_matcher" | No | If this parameter is specified, the information of load jobs whose labels contain label_matcheris returned. |
| AND | No |
| STATE | No | The states of load jobs. The states vary based on loading methods.
 STATEparameter is not specified, the information of load jobs in all states is returned by default. If theSTATEparameter is specified, only the information of load jobs in the given state is returned. For example,STATE = "PENDING"returns the information of load jobs in thePENDINGstate. |
| ORDER BY field_name [ASC | DESC] | No | If this parameter is specified, the output is sorted in ascending or descending order based on a field. The following fields are supported: JobId,Label,State,Progress,Type,EtlInfo,TaskInfo,ErrorMsg,CreateTime,EtlStartTime,EtlFinishTime,LoadStartTime,LoadFinishTime,URL, andJobDetails.
 JobIdby default. |
| LIMIT limit | No | The number of load jobs that are allowed to display. If this parameter is not specified, the information of all load jobs that match the filter conditions are displayed. If this parameter is specified, for example, LIMIT 10, only the information of 10 load jobs that match filter conditions are returned. |
| OFFSET offset | No | The offsetparameter defines the number of load jobs to be skipped. For example,OFFSET 5skips the first five load jobs and returns the rest. The value of theoffsetparameter defaults to0. |
Outputβ
| JobId | Label | State | Progress | Type | Priority | EtlInfo | TaskInfo | ErrorMsg | CreateTime | EtlStartTime | EtlFinishTime | LoadStartTime | LoadFinishTime | URL | JobDetails |
The output of this statement varies based on loading methods.
| Field | Broker Load | Spark Load | INSERT |
| JobId | The unique ID assigned by StarRocks to identify the load job in your StarRocks cluster. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| Label | The label of the load job. The label of a load job is unique within a database but can be duplicate across different databases. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| State | The state of the load job.
| Progress | The stage of the load job. A Broker Load job only has the LOADstage, which ranges from 0% to 100% to describe the progress of the stage. When the load job enters theLOADstage,LOADINGis returned for theStateparameter. A Broker Load job does not have theETLstage. TheETLparameter is valid only for a Spark Load job.Note
 | The stage of the load job. A Spark Load job has two stages:
 ETLstage,ETLis returned for theStateparameter. When the load job moves to theLOADstage,LOADINGis returned for theStateparameter.The Note is the same as those for Broker Load. | The stage of the load job. An INSERT job only has the LOADstage, which ranges from 0% to 100% to describe the progress of the stage. When the load job enters theLOADstage,LOADINGis returned for theStateparameter. An INSERT job does not have theETLstage. TheETLparameter is valid only for a Spark Load job.The Note is the same as those for Broker Load. |
| Type | The method of the load job. The value of this parameter defaults to BROKER. | The method of the load job. The value of this parameter defaults to SPARK. | The method of the load job. The value of this parameter defaults to INSERT. |
| Priority | The priority of the load job. Valid values: LOWEST, LOW, NORMAL, HIGH, and HIGHEST. | - | - |
| EtlInfo | The metrics related to ETL.
 max-filter-ratioparameter:dpp.abnorm.ALL/(unselected.rows+dpp.abnorm.ALL+dpp.norm.ALL). | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The metrics related to ETL. An INSERT job does not have the ETLstage. Therefore,NULLis returned. |
| TaskInfo | The parameters that are specified when you create the load job.
| ErrorMsg | The error message returned when the load job fails. When the state of the loading job is PENDING,LOADING, orFINISHED,NULLis returned for theErrorMsgfield. When the state of the loading job isCANCELLED, the value returned for theErrorMsgfield consists of two parts:typeandmsg.
 | The error message returned when the load job fails. When the state of the loading job is FINISHED,NULLis returned for theErrorMsgfield. When the state of the loading job isCANCELLED, the value returned for theErrorMsgfield consists of two parts:typeandmsg.
| CreateTime | The time at which the load job was created. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| EtlStartTime | A Broker Load job does not have the ETLstage. Therefore, the value of this field is the same as the value of theLoadStartTimefield. | The time at which the ETLstage starts. | An INSERT job does not have the ETLstage. Therefore, the value of this field is the same as the value of theLoadStartTimefield. |
| EtlFinishTime | A Broker Load job does not have the ETLstage. Therefore, the value of this field is the same as the value of theLoadStartTimefield. | The time at which the ETLstage finishes. | An INSERT job does not have the ETLstage. Therefore, the value of this field is the same as the value of theLoadStartTimefield. |
| LoadStartTime | The time at which the LOADstage starts. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| LoadFinishTime | The time at which the load job finishes. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| URL | The URL that is used to access the unqualified data detected in the load job. You can use the curlorwgetcommand to access the URL and obtain the unqualified data. If no unqualified data is detected,NULLis returned. | The field has the same meaning in a Spark Load job as it does in a Broker Load job. | The field has the same meaning in a INSERT job as it does in a Broker Load job. |
| JobDetails | Other information related to the load job.
Usage notesβ
The information returned by the SHOW LOAD statement is valid for 3 days from LoadFinishTimeof a load job. After 3 days, the information cannot be displayed. You can use thelabel_keep_max_secondparameter to modify the default validity period.ADMIN SET FRONTEND CONFIG ("label_keep_max_second" = "value");
If the value of the LoadStartTimefield isN/Afor a long time, it means that load jobs heavily pile up. We recommended that you reduce the frequency of creating load jobs.
Total time period consumed by a load job = LoadFinishTime-CreateTime.
Total time period a load job consumed in the LOADstage =LoadFinishTime-LoadStartTime.
Example 1: Vertically display all load jobs in your current database.
SHOW LOAD\G
         JobId: 976331
         Label: duplicate_table_with_null
         State: FINISHED
      Progress: ETL:100%; LOAD:100%
          Type: BROKER
      Priority: NORMAL
       EtlInfo: unselected.rows=0; dpp.abnorm.ALL=0; dpp.norm.ALL=65546
      TaskInfo: resource:N/A; timeout(s):300; max_filter_ratio:0.0
      ErrorMsg: NULL
    CreateTime: 2022-10-17 19:35:00
  EtlStartTime: 2022-10-17 19:35:04
 EtlFinishTime: 2022-10-17 19:35:04
 LoadStartTime: 2022-10-17 19:35:04
LoadFinishTime: 2022-10-17 19:35:06
           URL: NULL
    JobDetails: {"Unfinished backends":{"b90a703c-6e5a-4fcb-a8e1-94eca5be0b8f":[]},"ScannedRows":65546,"TaskNumber":1,"All backends":{"b90a703c-6e5a-4fcb-a8e1-94eca5be0b8f":[10004]},"FileNumber":1,"FileSize":548622}
Example 2: Display two load jobs whose labels contain the string null in your current database.
SHOW LOAD
WHERE LABEL LIKE "null"
LIMIT 2;
| JobId | Label                     | State    | Progress            | Type   | EtlInfo                                                 | TaskInfo        | ErrorMsg | CreateTime          | EtlStartTime        | EtlFinishTime       | LoadStartTime       | LoadFinishTime      | URL        | JobDetails        |
| 10082 | duplicate_table_with_null | FINISHED | ETL:100%; LOAD:100% | BROKER | unselected.rows=0; dpp.abnorm.ALL=0; dpp.norm.ALL=65546 | resource:N/A; timeout(s):300; max_filter_ratio:0.0                                                      | NULL     | 2022-08-02 14:53:27 | 2022-08-02 14:53:30 | 2022-08-02 14:53:30 | 2022-08-02 14:53:30 | 2022-08-02 14:53:31 | NULL        | {"Unfinished backends":{"4393c992-5da1-4e9f-8b03-895dc0c96dbc":[]},"ScannedRows":65546,"TaskNumber":1,"All backends":{"4393c992-5da1-4e9f-8b03-895dc0c96dbc":[10002]},"FileNumber":1,"FileSize":548622} |
| 10103 | unique_table_with_null    | FINISHED | ETL:100%; LOAD:100% | SPARK  | unselected.rows=0; dpp.abnorm.ALL=0; dpp.norm.ALL=65546 | resource:test_spark_resource_07af473a_1230_11ed_b483_00163e0e550b; timeout(s):300; max_filter_ratio:0.0 | NULL     | 2022-08-02 14:56:06 | 2022-08-02 14:56:19 | 2022-08-02 14:56:41 | 2022-08-02 14:56:41 | 2022-08-02 14:56:44 | http://emr-header-1.cluster-49091:20888/proxy/application_1655710334658_26391/ | {"Unfinished backends":{"00000000-0000-0000-0000-000000000000":[]},"ScannedRows":65546,"TaskNumber":1,"All backends":{"00000000-0000-0000-0000-000000000000":[-1]},"FileNumber":1,"FileSize":8790855}   |
Example 3: Display the load jobs whose labels contain the string table in example_db. In addition, the load jobs returned are displayed in descending order of the LoadStartTime field.
SHOW LOAD FROM example_db
WHERE LABEL Like "table"
ORDER BY LoadStartTime DESC;
Example 4: Display the load job whose label is duplicate_table_with_null and state is FINISHED in example_db.
WHERE LABEL = "duplicate_table_with_null" AND STATE = "FINISHED";
Example 5: Skip the first load job and display the next two load jobs. In addition, these two load jobs are sorted in ascending order.
ORDER BY CreateTime ASC
LIMIT 2 OFFSET 1;
Or
LIMIT 1,2;
The output of the preceding statements is as follows.
| 10120 | insert_3a57b595-1230-11ed-b075-00163e14c85e | FINISHED | ETL:100%; LOAD:100% | INSERT | NULL                                                    | resource:N/A; timeout(s):3600; max_filter_ratio:0.0                                                     | NULL     | 2022-08-02 14:56:26 | 2022-08-02 14:56:26 | 2022-08-02 14:56:26 | 2022-08-02 14:56:26 | 2022-08-02 14:56:26 |        | {"Unfinished backends":{},"ScannedRows":0,"TaskNumber":0,"All backends":{},"FileNumber":0,"FileSize":0}        |
