Version: Candidate-4.0
SHOW USERS
SHOW USERS displays all users in the system. Users mentioned here are user identities, not user names. For more information about user identities, see CREATE USER. This command is supported from v3.0.
You can use SHOW GRANTS FOR <user_identity>; to view the privileges of a specific user. For more information, see SHOW GRANTS.
tip
Only users with the user_admin role has the privilege to perform this operation.
SHOW USERS
Return fields:
FieldDescription
UserThe user identity.
Display all users in the system.
mysql> SHOW USERS;
| User |
| 'wybing5'@'%' |
| 'root'@'%' |
| 'admin'@'%' |
| 'star'@'%' |
| 'wybing_30'@'%' |
| 'simo'@'%' |
| 'wybing1'@'%' |
| 'wybing2'@'%' |
References​
CREATE USER, ALTER USER, DROP USER
