SHOW GRANTS
SHOW GRANTS displays all the privileges that have been granted to a user or role.
For more information about roles and privileges, see Overview of privileges.
tip
All roles and users can view the privileges granted to them or the roles assigned to them. Only users with the user_admin role can view the privileges of a specified user or role.
SHOW GRANTS; -- View the privileges of the current user.
SHOW GRANTS FOR ROLE <role_name>; -- View the privileges of a specific role.
SHOW GRANTS FOR <user_identity>; -- View the privileges of a specific user.
Parametersβ
- role_name
- user_identity
Return fields:
|UserIdentity  |Catalog | Grants                                      |
|RoleName     |Catalog | Grants                                                |
| Field | Description |
| UserIdentity | The user identity, which is displayed when you query the privileges of a user. |
| RoleName | The role name, which is displayed when you query the privileges of a role. |
| Catalog | The catalog name. defaultis returned if the GRANT operation is performed on the StarRocks internal catalog.The name of the external catalog is returned if the GRANT operation is performed on an external catalog. NULLis returned if the operation shown in theGrantscolumn is assigning roles. |
| Grants | The specific GRANT operation. |
mysql> SHOW GRANTS;
| UserIdentity | Catalog | Grants                                 |
| 'root'@'%'   | NULL    | GRANT 'root', 'testrole' TO 'root'@'%' |
mysql> SHOW GRANTS FOR 'user_g'@'%';
|UserIdentity |Catalog      |Grants        |
|'user_g'@'%' |NULL         |GRANT role_g, public to `user_g`@`%`;                                                          |
|'user_g'@'%' |NULL         |GRANT IMPERSONATE ON USER `user_a`@`%` TO USER `user_g`@`%`;                                |
|'user_g'@'%' |default      |GRANT CREATE_DATABASE ON CATALOG default_catalog TO USER `user_g`@`%`;                         |
|'user_g'@'%' |default      |GRANT ALTER, DROP, CREATE_TABLE ON DATABASE db1 TO USER `user_g`@`%`;                          |
|'user_g'@'%' |default      |GRANT CREATE_VIEW ON DATABASE db1 TO USER `user_g`@`%` WITH GRANT OPTION;                      |
|'user_g'@'%' |default      |GRANT ALTER, DROP, SELECT, INGEST, EXPORT, DELETE, UPDATE ON TABLE db.* TO USER `user_g`@`%`;  |
|'user_g'@'%' |default      |GRANT ALTER, DROP, SELECT ON VIEW db2.view TO USER `user_g`@`%`;                               |
|'user_g'@'%' |Hive_catalog |GRANT USAGE ON CATALOG Hive_catalog TO USER `user_g`@`%`                                       |
mysql> SHOW GRANTS FOR ROLE role_g;
|role_g       |NULL    | GRANT role_p, role_test TO ROLE role_g;               |
|role_g       |default | GRANT SELECT ON *.* TO ROLE role_g WITH GRANT OPTION; |
