SET PASSWORD
SET PASSWORD changes the login password for users. The ALTER USER command can also be used to change a password.
tip
- All users can reset their own password.
- Only users with the user_adminrole can change the password of other users.
- Only the rootuser itself can change its password. For more information, see the priviege overview.
SET PASSWORD [FOR user_identity] =
[PASSWORD('plain password')]|['hashed password']
The user_identity must match exactly the user_identity specified when creating a user by using CREATE USER. Otherwise, the user will be reported as non-existent. If user_identity is not specified, the password of the current user will be changed. The current user can be viewed through SHOW GRANTS.
PASSWORD() inputs a plaintext password. If you directly input a string without using PASSWORD(), the string must be encrypted.
Set the password for the current user. SET PASSWORD = PASSWORD('123456')
 SET PASSWORD = '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9'
Set the password for a specified user. SET PASSWORD FOR 'jack'@'192.%' = PASSWORD('123456')
 SET PASSWORD FOR 'jack'@['domain'] = '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9'
