EXECUTE AS
Use the IMPERSONATE privilege with EXECUTE AS statements to switch the execution context of the current session to the impersonated user.
This command is supported from v2.4.
EXECUTE AS user WITH NO REVERT
Parametersβ
user: The user must already exist.
Usage notesβ
- The current login user (who calls the EXECUTE AS statement) must be granted the privilege to impersonate another user. For more information, see GRANT.
- The EXECUTE AS statement must contain the WITH NO REVERT clause, which means the execution context of the current session cannot be switched back to the original login user before the current session ends.
Switch the execution context of the current session to the user test2.
EXECUTE AS test2 WITH NO REVERT;
After the switch succeeds, you can run the select current_user() command to obtain the current user.
select current_user();
| CURRENT_USER()              |
| 'default_cluster:test2'@'%' |
