ALTER USER
ALTER USER modifies user information, including password, authentication method, default roles, and user properties (supported from v3.3.3 onwards).
Common users can use this command to modify information for themselves. Only users with the user_admin role can modify information for other users.
ALTER USER user_identity
[auth_option]
[default_role]
[SET PROPERTIES ("key"="value", ...)]
Parametersβ
user_identityconsists of two parts, "user_name" and "host", in the format ofusername@'userhost'. For the "host" part, you can use%for fuzzy match. If "host" is not specified, "%" is used by default, meaning that the user can connect to StarRocks from any host. However, when you use this statement withSET PROPERTIESto modify the user properties, you must specify theusernameinstead ofuser_identity.
auth_optionspecifies the authentication method. Currently, three authentication methods are supported: StarRocks native password, mysql_native_password, and "authentication_ldap_simple". StarRocks native password is the same as mysql_native_password in logic but slightly differs in syntax. One user identity can use only one authentication method. You can use ALTER USER to modify users' passwords and authentication methods.auth_option: {
 IDENTIFIED BY 'auth_string'
 }Authentication method Password for user creation Password for login Native password Plaintext or ciphertext Plaintext mysql_native_password BYPlaintext Plaintext mysql_native_password WITHCiphertext Plaintext authentication_ldap_simplePlaintext Plaintext
Note: StarRocks encrypts users' passwords before storing them.
DEFAULT ROLEsets the default role for the user.-- Set specified roles as default roles.
 -- Set all roles of the user, including roles that will be assigned to this user, as default roles.
 DEFAULT ROLE ALL
 -- No default role is set but the public role is still enabled after a user login.
 DEFAULT ROLE NONEBefore you run ALTER USER to set default roles, make sure that all the roles have been assigned to users. The roles are automatically activated after the user logs in again.
SET PROPERTIESsets user properties, including the maximum user connection number (max_user_connections), catalog, database or session variables on the user level. User-level session variables take effect as the user logs in. This feature is supported from v3.3.3.-- Set the maximum user connection number.
 SET PROPERTIES ("max_user_connections" = "<Integer>")
 -- Set the catalog.
 SET PROPERTIES ("catalog" = "<catalog_name>")
 -- Set the database.
 SET PROPERTIES ("catalog" = "<catalog_name>", "database" = "<database_name>")
 -- Set session variables.
 SET PROPERTIES ("session.<variable_name>" = "<value>", ...)
 -- Clear the properties set for the user.
 SET PROPERTIES ("catalog" = "", "database" = "", "session.<variable_name>" = "");tip- SET PROPERTIESworks on user instead of user identity. Therefore, when modifying the user properties, you must specify the- usernameinstead of- user_identityin the- ALTER USERstatement.
- Global variables and read-only variables cannot be set for a specific user.
- Variables take effect in the following order: SET_VAR > Session > User property > Global.
- You can use SHOW PROPERTY to view the properties of a specific user.
Example 1: Change user's password to a plaintext password.
ALTER USER 'jack' IDENTIFIED BY '123456';
ALTER USER jack@'172.10.1.10' IDENTIFIED WITH mysql_native_password BY '123456';
Example 2: Change user's password to a ciphertext password.
ALTER USER jack@'172.10.1.10' IDENTIFIED BY PASSWORD '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9';
ALTER USER jack@'172.10.1.10' IDENTIFIED WITH mysql_native_password AS '*6BB4837EB74329105EE4568DDA7DC67ED2CA2AD9';
You can get the encrypted password using the password() function.
Example 3: Change the authentication method to LDAP.
ALTER USER jack@'172.10.1.10' IDENTIFIED WITH authentication_ldap_simple;
Example 4: Change the authentication method to LDAP and specify the distinguished name (DN) of the user in LDAP.
ALTER USER jack@'172.10.1.10' IDENTIFIED WITH authentication_ldap_simple AS 'uid=jack,ou=company,dc=example,dc=com';
Example 5: Change the default roles of the user to db_admin and user_admin. Note that the user must have been assigned these two roles.
ALTER USER 'jack'@'192.168.%' DEFAULT ROLE db_admin, user_admin;
Example 6: Set all roles of the user, including roles that will be assigned to this user as default roles.
ALTER USER 'jack'@'192.168.%' DEFAULT ROLE ALL;
Example 7: Clear all the default roles of the user.
ALTER USER 'jack'@'192.168.%' DEFAULT ROLE NONE;
Note: By default, the
publicrole is still activated for the user.
Example 8: Set the maximum user connection number to 600.
ALTER USER 'jack' SET PROPERTIES ("max_user_connections" = "600");
Example 9: Set the catalog of the user to hive_catalog.
ALTER USER 'jack' SET PROPERTIES ('catalog' = 'hive_catalog');
Example 10: Set the database of the user to test_db in the default catalog.
ALTER USER 'jack' SET PROPERTIES ('catalog' = 'default_catalog', 'database' = 'test_db');
Example 11: Set the session variable query_timeout to 600 for the user.
Example 12: Clear the properties set for the user.
ALTER USER 'jack' SET PROPERTIES ('catalog' = '', 'database' = '', 'session.query_timeout' = '');
