array_sum
Sums all the elements in an array.
From StarRocks 2.5, array_sum() can take a lambda expression as an argument. However, it cannot work directly with the Lambda expression. It must work on the result converted from array_map().
array_sum(array(type))
array_sum(lambda_function, arr1,arr2...) = array_sum(array_map(lambda_function, arr1,arr2...))
Parametersβ
- array(type): the array you want to calculate the sum. Array elements support the following data types: BOOLEAN, TINYINT, SMALLINT, INT, BIGINT, LARGEINT, FLOAT, DOUBLE, and DECIMALV2.
- lambda_function: the lambda expression used to calculate the target array for array_sum().
Return valueβ
Returns a numeric value.
Use array_sum without lambda functionβ
mysql> select array_sum([11, 11, 12]);
| array_sum([11,11,12]) |
| 34                    |
mysql> select array_sum([11.33, 11.11, 12.324]);
| array_sum([11.33,11.11,12.324]) |
| 34.764                          |
Use array_sum with lambda functionβ
-- Multiply [1,2,3] by [1,2,3] and sum the elements.
select array_sum(array_map(x->x*x,[1,2,3]));
| array_sum(array_map(x -> x * x, [1, 2, 3])) |
|                                          14 |
keywordβ
ARRAY_SUM,ARRAY
