any_match
Returns whether any elements of an array match the given predicate.
Returns true(1) if one or more elements match the predicate.
Returns false(0) if none of the elements matches (a special case is when the array is empty).
Returns NULL if the predicate returns NULL for one or more elements and falsefor all other elements.
This function is supported from v3.0.6 onwards.
any_match(lambda_function, arr1, arr2...)
Returns whether any elements of arr1 match the given predicate in the lambda function.
Parametersβ
arr1: the array to match.
arrN: optional arrays used in the lambda function.
lambda_function: the lambda function used to match values.
Return valueβ
Returns a BOOLEAN value.
Usage notesβ
- The lambda function follows the usage notes in array_map().
- If the input array is null or the lambda function results in null, null is returned.
- If arr1is empty,falseis returned.
- To apply this function to MAP, rewrite any_match((k,v)->k>v,map)toany_match(map_values(transform_values((k,v)->k>v, map))). For example,select any_match(map_values(transform_values((k,v)->k>v, map{2:1})));returns 1.
Check whether any element in x is less than the elements in y.
select any_match((x,y) -> x < y, [1,2,8], [4,5,6]);
| any_match((x, y) -> x < y, [1, 2, 8], [4, 5, 6]) |
|                                                1 |
select any_match((x,y) -> x < y, [11,12,8], [4,5,6]);
| any_match((x, y) -> x < y, [11, 12, 8], [4, 5, 6]) |
|                                                  0 |
select any_match((x,y) -> x < y, [11,12,null], [4,5,6]);
| any_match((x, y) -> x < y, [11, 12, NULL], [4, 5, 6]) |
|                                                  NULL |
select any_match((x,y) -> x < y, [], []);
| any_match((x, y) -> x < y, [], []) |
|                                  0 |
select any_match((x,y) -> x < y, null, [4,5,6]);
| any_match((x, y) -> x < y, NULL, [4, 5, 6]) |
|                                        NULL |
