Flat JSON
This article introduces the basic concept of Flat JSON and how to use this feature.
Starting from version 2.2.0, StarRocks supports the JSON data type to allow more flexible data storage. However, when querying JSON, most scenarios do not involve directly reading the entire JSON data but rather accessing data at specified paths. For example:
-- Store required fields in logs as fixed fields, and package other fields that frequently change with business as JSON.
    time,
    event,
    user,
FROM logs;
Due to the special nature of the JSON type, its performance in queries is not as good as standard types (INT, STRING, etc.). The reasons include:
- Storage overhead: JSON is a semi-structured type that requires storing the structure information of each row, leading to high storage usage and low compression efficiency.
- Query complexity: Queries need to detect data structures based on runtime data, making it difficult to achieve vectorized execution optimization.
- Redundant data: Queries need to read the entire JSON data, which includes many redundant fields.
StarRocks introduces the Flat JSON feature to improve JSON data query efficiency and reduce the complexity of using JSON.
- This feature is available from version 3.3.0, disabled by default, and needs to be enabled manually.
What is Flat JSONβ
The core principle of Flat JSON is to detect JSON data during load and extract common fields from JSON data for storage as standard type data. When querying JSON, these common fields optimize the query speed of JSON. Example data:
2, {"a": 2, "b": 22, "d": 4}
6, {"c": 6, "d": 1}
When loading the above JSON data, fields a and b are present in most JSON data and have similar data types (both INT). Therefore, the data of fields a and b can be extracted from JSON and stored separately as two INT columns. When these two columns are used in queries, their data can be directly read without needing to process additional JSON fields, reducing the computational overhead of handling JSON structures.
Enable Flat JSONβ
Flat JSON is enabled globally by default from v3.4 onwards. For versions earlier than v3.4, you must manually enable it.
From v4.0, this feature can be configured on the table level.
Enable for versions earlier than v3.4β
Modify BE configuration: enable_json_flat, which defaults tofalsebefore v3.4. For modification methods, refer to Configure BE parameters.
Enable FE pruning feature: SET GLOBAL cbo_prune_json_subfield = true;
Enable Flat JSON Feature on table levelβ
Setting Flat JSON-related properties on table level is supported from v4.0 onwards.
When creating the table, you can set flat_json.enableand other Flat JSON-related properties. For detailed instructions, see CREATE TABLE.Alternatively, you can set these properties using ALTER TABLE. Example: ALTER TABLE t1 SET ("flat_json.enable" = "true");
 ALTER TABLE t1 SET ("flat_json.null.factor" = "0.1");
 ALTER TABLE t1 SET ("flat_json.sparsity.factor" = "0.8");
 ALTER TABLE t1 SET ("flat_json.column.max" = "90");
Verify if Flat JSON is Effectiveβ
After loading data, you can query the extracted sub-columns of the corresponding column:
FROM <table_name>[_META_];
You can verify whether the executed query benefits from Flat JSON optimization through the Query Profile by observing the following metrics:
- PushdownAccessPaths: The number of sub-field paths pushed down to storage.
- AccessPathHits: The number of times Flat JSON sub-fields are hit, with detailed information on the specific JSON hit.
- AccessPathUnhits: The number of times Flat JSON sub-fields are not hit, with detailed information on the specific JSON not hit.
- JsonFlattern: The time taken to extract sub-columns on-site when Flat JSON is not hit.
Usage Exampleβ
Method 1: Configure Flat JSON properties when creating a table with JSON columns. Supported from v4.0 onwards. CREATE TABLE `t1` (
 `k1` int,
 `k2` JSON,
 `k3` VARCHAR(20),
 `k4` JSON
 DUPLICATE KEY(`k1`)
 "flat_json.enable" = "true",
 "flat_json.column.max" = "50");
 INSERT INTO t1 (k1,k2) VALUES
 (20,parse_json('{"str":"test_str6","Integer":444,"Double":3.14,"Object":{"a":"b"},"arr":[1,2,3],"Bool":true,"null":null}'));
Method 2: Enable Flat JSON before creating the table.
Enable the feature (refer to other sections)
Create a table with JSON columns. In this example, use INSERT INTO to load JSON data into the table. CREATE TABLE `t1` (
 `k1` int,
 `k2` JSON,
 `k3` VARCHAR(20),
 `k4` JSON
 DUPLICATE KEY(`k1`)
View the extracted sub-columns for the k2column.SELECT flat_json_meta(k2) FROM t1[_META_];
 | flat_json_meta(k2) |
Execute data queries. SELECT * FROM t1;
 SELECT get_json_string(k2,'\$.Bool') FROM t1 WHERE k2->'arr' = '[10,20,30]';
View Flat JSON-related metrics in the Query Profile PushdownAccessPaths: 2
 - Table: t1
 - AccessPathHits: 2
 - __MAX_OF_AccessPathHits: 1
 - __MIN_OF_AccessPathHits: 1
 - /k2: 2
 - __MAX_OF_/k2: 1
 - __MIN_OF_/k2: 1
 - AccessPathUnhits: 0
 - JsonFlattern: 0ns
Related variables and configurationsβ
Session variablesβ
- cbo_json_v2_rewrite(default: true): Enables JSON v2 path rewrite so that expressions like- get_json_*can be rewritten to direct access of Flat JSON subcolumns, unlocking predicate pushdown and column pruning.
- cbo_json_v2_dict_opt(default: true): Enables low-cardinality dictionary optimization for Flat JSON extended string subcolumns produced by the rewrite, which can speed up string expressions, GROUP BY, and JOIN.
Example:
SET cbo_json_v2_rewrite = true;
SET cbo_json_v2_dict_opt = true;
BE Configurationsβ
- json_flat_null_factor
- json_flat_column_max
- json_flat_sparsity_factor
- enable_compaction_flat_json
- enable_lazy_dynamic_flat_json
Feature Limitationsβ
- All table types in StarRocks support Flat JSON.
- Compatible with historical data without needing re-import. Historical data will coexist with data flattened by Flat JSON.
- Historical data will not automatically apply Flat JSON optimization unless new data is loaded or Compaction occurs.
- Enabling Flat JSON will increase the time taken to load JSON. The more JSON extracted, the longer it takes.
- Flat JSON can only support materializing common keys in JSON Objects, not keys in JSON Arrays.
- Flat JSON does not change the data sorting method, so query performance and data compression rate will still be affected by data sorting. To achieve optimal performance, further adjustments to data sorting may be necessary.
Version Notesβ
StarRocks shared-nothing clusters support Flat JSON starting from v3.3.0, and shared-data clusters support it from v3.3.3.
In versions v3.3.0, v3.3.1, and v3.3.2:
- When loading data, it supports extracting common fields and storing them separately as JSON types, without type inference.
- Both the extracted columns and the original JSON data are stored. The extracted data will be deleted along with the original data.
Starting from version v3.3.3:
- The results extracted by Flat JSON are divided into common columns and reserved field columns. When all JSON Schemas are consistent, no reserved field columns are generated.
- Flat JSON only stores common field columns and reserved field columns, without additionally storing the original JSON data.
- When loading data, common fields will automatically infer types as BIGINT/LARGEINT/DOUBLE/STRING. Unrecognized types will be inferred as JSON types, and reserved field columns will be stored as JSON types.
