Version: Candidate-4.0
is_role_in_session
Verifies whether a role (or a nested role) is active in the current session.
This function is supported from v3.1.4 onwards.
BOOLEAN is_role_in_session(VARCHAR role_name);
role_name: the role you want to verify (can also be a nested role). Supported data type is VARCHAR.
Returns a BOOLEAN value. 1 indicates the role is active in the current session. 0 indicates the opposite.
  1. Create roles and a user.
    -- Create three roles.
    create role r1;
    create role r2;
    create role r3;
    -- Create user u1.
    create user u1;
    -- Pass roles r2 and r3 to r1, and grant r1 to user u1. This way, user u1 has three roles: r1, r2, and r3.
    grant r3 to role r2;
    grant r2 to role r1;
    grant r1 to user u1;
    -- Switch to user u1 and perform operations as u1.
    execute as u1 with no revert;
  2. Verify whether r1 is active. The result shows this role is not active.
    select is_role_in_session("r1");
    | is_role_in_session('r1') |
    | 0 |
  3. Run the SET ROLE command to activate r1 and use is_role_in_session to verify whether the role is active. The result shows r1 is active and roles r2 and r3 that are nested in r1 are also active.
    set role "r1";
    select is_role_in_session("r2");
    | is_role_in_session('r2') |
    select is_role_in_session("r3");
    | is_role_in_session('r3') |
