Version: Candidate-4.0
hll_empty
Generates an empty HLL column to supplement the default values when inserting or loading data.
HLL_EMPTY()
Returns an empty HLL.
Supplement the default values when inserting data.
insert into hllDemo(k1,v1) values(10,hll_empty());
Supplement the default values when loading data.
-T example7.csv -XPUT \
