inspect_table_partition_info
inspect_table_partition_info(table_name)
This function returns partition information of a table.
Argumentsβ
table_name: The name of the table (VARCHAR).
Return Valueβ
Returns a VARCHAR string containing the partition information of the table in JSON format.
Example 1: Inspect a table's partitino information:
mysql> select inspect_table_partition_info('ss');
| inspect_table_partition_info('ss') |
| {"ss":{"id":28672,"version":4,"lastRefreshTime":1751439875145,"lastFileModifiedTime":-1,"fileNumber":-1}} |
