inspect_mv_refresh_info
inspect_mv_refresh_info(mv_name)
This function returns refresh information of a materialized view.
Argumentsβ
mv_name: The name of the materialized view (VARCHAR).
Return Valueβ
Returns a VARCHAR string containing the refresh information of the materialized view in JSON format including:
- tableToUpdatePartitions: the mv's base tables' to-refresh partition meta infos;
- baseOlapTableVisibleVersionMap: the mv's olap base tables' already refreshed version map;
- baseExternalTableInfoVisibleVersionMap: the mv's external base tables' already refreshed version map;
Example 1: Inspect a materialized view's refresh information to check its current refresh status:
mysql> select inspect_mv_refresh_info('test_mv1');
| inspect_mv_refresh_info('test_mv1')        |
| {"tableToUpdatePartitions":{},"baseOlapTableVisibleVersionMap":{"ss":{"ss":{"id":28672,"version":4,"lastRefreshTime":1751439875145,"lastFileModifiedTime":-1,"fileNumber":-1}}},"baseExternalTableInfoVisibleVersionMap":{}} |
