inspect_memory_detail
inspect_memory_detail(module_name, class_info)
This function returns the estimated memory usage for a specific class or field within a module.
Argumentsβ
module_name: The name of the module (VARCHAR).
class_info: The name of the class or 'class_name.field_name' (VARCHAR).
NOTE:
- The following module names are supported (for more details, see the MemoryUsageTracker.javaclass):
- Load
- Compaction
- Export
- Delete
- Transaction
- Backup
- Task
- TabletInvertedIndex
- LocalMetastore
- Report
- MV
- Query
- Profile
- Agent
- Statistics
- Coordinator
- Dict
- class_infocan be a class or a class's field of the specific class(for more details, see the- MemoryUsageTracker.javaclass).
Return Valueβ
Returns a VARCHAR string representing the estimated memory size (e.g., "100MB").
Example 1: Inspect Task module TaskManager's memory usage:
mysql> select inspect_memory_detail('Task', 'TaskManager');
| inspect_memory_detail('Task', 'TaskManager') |
| 0B                                           |
Example 2: Inspect Task module TaskManager's taskRunManager field's memory usage:
mysql> select inspect_memory_detail('Task', 'TaskManager.taskRunManager');
| inspect_memory_detail('Task', 'TaskManager.taskRunManager') |
| 592B                                                        |
