Version: Candidate-4.0
transform_values
Transforms values in a map using a Lambda expression and produces a new value for each entry in the map.
MAP transform_values(lambda_func, any_map)
lambda_func can also be placed after any_map:
MAP transform_values(any_map, lambda_func)
  • any_map: the Map.
  • lambda_func: the Lambda expression you want to apply to any_map.
Returns a map value where the data types of values are determined by the result of the Lambda expression and the data types of keys are the same as keys in any_map.
If any input parameter is NULL, NULL is returned.
If a key or value in the original map is NULL, NULL is processed as a normal value.
The Lambda expression must have two parameters. The first parameter represents the key. The second parameter represents the value.
The following example uses map_from_arrays to generate a map value {1:"ab",3:"cdd",2:null,null:"abc"}. Then the Lambda expression is applied to each value of the map. The first example changes the value of each key-value pair to 1. The second example changes the value of each key-value pair to null.
mysql> select transform_values((k,v)->1, col_map) from (select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']) as col_map)A;
| transform_values((k, v) -> 1, col_map) |
| {1:1,3:1,2:1,null:1} |
1 row in set (0.02 sec)
mysql> select transform_values((k,v)->null, col_map) from (select map_from_arrays([1,3,null,2,null],['ab','cdd',null,null,'abc']) as col_map)A;
| transform_values((k, v) -> NULL, col_map) |
| {1:null,3:null,2:null,null:null} |
