Version: Candidate-4.0
base64_decode_binary
Decodes a Base64-encoded string and return a BINARY.
base64_decode_binary(str);
str: the string to decode. It must be of the VARCHAR type.
Returns a value of the VARBINARY type. If the input is NULL or an invalid Base64 string, NULL is returned. If the input is empty, an error is returned.
This function accepts only one string. More than one input string causes an error.
mysql> select hex(base64_decode_binary(to_base64("Hello StarRocks")));
| hex(base64_decode_binary(to_base64('Hello StarRocks'))) |
| 48656C6C6F2053746172526F636B73 |
mysql> select base64_decode_binary(NULL);
| base64_decode_binary(NULL) |
