Version: Candidate-4.0
unnest_bitmap
unnest_bitmap is a table function that takes a bitmap and converts elements in that bitmap into multiple rows of a table.
StarRocks' Lateral Join can be used in conjunction with the unnest_bitmap function to implement common column-to-row logic.
This function can be used to replace unnest(bitmap_to_array(bitmap)). It has better performance, takes up less memory resources, and is not limited by the length of the array.
This function is supported from v3.1.
unnest_bitmap(bitmap)
bitmap: the bitmap you want to convert.
Returns multiple rows converted from the bitmap. The type of return value is BIGINT.
c2 is a bitmap column in table t1.
-- Use the bitmap_to_string function to convert values in the c2 column into a string.
| c1 | bitmap_to_string(c2) |
| 1 | 1,2,3,4,5,6,7,8,9,10 |
-- Use the unnest_bitmap function to expand the bitmap column into multiple rows.
mysql> select c1, unnest_bitmap from t1, unnest_bitmap(c2);
| c1 | unnest_bitmap |
| 1 | 1 |
| 1 | 2 |
| 1 | 3 |
| 1 | 4 |
| 1 | 5 |
| 1 | 6 |
| 1 | 7 |
| 1 | 8 |
| 1 | 9 |
| 1 | 10 |
