Version: Candidate-4.0
bitmap_union_int
Count the number of different values ​​in columns of type TINYINT, SMALLINT and INT, return the sum of COUNT (DISTINCT expr) same.
BIGINT bitmap_union_int(expr)
expr: column expression. The supported column type is TINYINT, SMALLINT and INT.
Returns a value of the BIGINT type.
mysql> select bitmap_union_int(k1) from tbl1;
| bitmap_union_int(`k1`) |
| 2 |
