Version: Candidate-4.0
bitmap_to_string
Converts an input bitmap into a string that is separated by commas (,). This string contains all the bits in the bitmap. If the input is null, null is returned.
VARCHAR BITMAP_TO_STRING(BITMAP input)
input: the bitmap you want to convert.
Returns a value of the VARCHAR type.
Example 1: The input is null and null is returned.
MySQL > select bitmap_to_string(null);
| bitmap_to_string(NULL) |
Example 2: The input is empty and an empty string is returned.
MySQL > select bitmap_to_string(bitmap_empty());
Example 3: Convert a bitmap that contains one bit into a string.
MySQL > select bitmap_to_string(to_bitmap(1));
| bitmap_to_string(to_bitmap(1)) |
Example 4: Convert a bitmap that contains two bits into a string.
MySQL > select bitmap_to_string(bitmap_or(to_bitmap(1), to_bitmap(2)));
| bitmap_to_string(bitmap_or(to_bitmap(1), to_bitmap(2))) |
| 1,2 |
