Version: Candidate-4.0
bitmap_from_binary
Converts a binary string with a specific format to a bitmap.
This function can be used to load bitmap data to StarRocks.
BITMAP bitmap_from_binary(VARBINARY str)
str: The supported data type is VARBINARY.
Returns a value of the BITMAP type.
Example 1: Use this function with other Bitmap functions.
mysql> select bitmap_to_string(bitmap_from_binary(bitmap_to_binary(bitmap_from_string("0,1,2,3"))));
| bitmap_to_string(bitmap_from_binary(bitmap_to_binary(bitmap_from_string('0,1,2,3')))) |
| 0,1,2,3 |
