to_binary
Converts a VARCHAR string to a binary value based on the specified binary format (binary_type) of the input string. The following binary formats are supported: hex, encode64, and utf8. If no binary_type is specified, hex is the default.
to_binary(str[, binary_type])
Parametersβ
str: the string to convert, required. It must be a VARCHAR string.
binary_type: the binary format for conversion, optional.- hex(default):- to_binaryassumes the input string is a hex string in which all characters are in '0123456789abcdef'. If the input string is not valid, an empty binary is returned (exceptions will not be thrown).- to_binarywill convert the input string into binary directly. For example,- "abab"will be converted to- x'abab'. The input string is not case-sensitive.
- encode64:- to_binaryassumes the input string is a base64-encoded string . If the input string is not valid, an empty binary is returned (exceptions will not be thrown).- to_binarywill decode the base64-encoded string as the binary result. For example,- "YWJhYg=="will be converted to- x'abab'.
- utf8:- to_binaryconverts the input string as a binary value without any transformation.
Return valueβ
Returns a VARCHAR value.
The following examples assume that the --binary-as-hex option is enabled when you access StarRocks from your MySQL client. This way, binary data is displayed using hexadecimal notation.
mysql> select to_binary('ABAB', 'hex');
| to_binary('ABAB', 'hex')                           |
| 0xABAB                                             |
mysql> select to_binary('U1RBUlJPQ0tT', 'encode64');
| to_binary('U1RBUlJPQ0tT', 'encode64')                                        |
| 0x53544152524F434B53                                                         |
mysql> select to_binary('STARROCKS', 'utf8');
| to_binary('STARROCKS', 'utf8')                                 |
-- The input string does not match the binary format and an empty binary is returned.
mysql> select to_binary('U1RBUlJPQ0tT', 'hex');
| to_binary('U1RBUlJPQ0tT', 'hex')                                   |
| 0x        |
