from_binary
Converts a binary value to a VARCHAR string based on the specified binary format (binary_type). The following binary formats are supported: hex, encode64, and utf8. If no binary_type is specified, hex is the default.
from_binary(binary[, binary_type])
Parametersβ
binary: the input binary to convert, required.
binary_type: the binary format for conversion, optional.- hex(default):- from_binaryuses the- hexmethod to encode the input binary to a VARCHAR string.
- encode64:- from_binaryuses the- base64method to encode the input binary to a VARCHAR string.
- utf8:- from_binaryconverts the input binary to a VARCHAR string without any transformation.
Return valueβ
Returns a VARCHAR string.
mysql> select from_binary(to_binary('ABAB', 'hex'), 'hex');
| from_binary(to_binary('ABAB', 'hex'), 'hex') |
| ABAB                                         |
1 row in set (0.02 sec)
mysql> select from_base64(from_binary(to_binary('U1RBUlJPQ0tT', 'encode64'), 'encode64'));
| from_base64(from_binary(to_binary('U1RBUlJPQ0tT', 'encode64'), 'encode64')) |
| STARROCKS        |
mysql> select from_binary(to_binary('STARROCKS', 'utf8'), 'utf8');
| from_binary(to_binary('STARROCKS', 'utf8'), 'utf8') |
| STARROCKS                                           |
