array_unique_agg
Aggregates distinct values (including NULL) in an ARRAY column into an array (from multiple rows to one row).
This function is supported from v3.2.
ARRAY_UNIQUE_AGG(col)
Parametersβ
col: the column whose values you want to aggregate. Supported data type is ARRAY.
Return valueβ
Returns a value of the ARRAY type.
Usage notesβ
- The order of the elements in an array is random.
- The data type of the elements in the returned array is the same as the data type of the elements in the input column.
- Returns
NULLif there is no matched value.
Take the following data table as an example:
mysql > select * from array_unique_agg_example;
| a | b |
| 2 | [1,null,2,4] |
| 2 | [1,null,3] |
| 1 | [1,1,2,3] |
| 1 | [2,3,4] |
Example 1: Group the values in column a and aggregate distinct values in column b into an array.
mysql > select a, array_unique_agg(b) from array_unique_agg_example group by a;
| a | array_unique_agg(b) |
| 1 | [4,1,2,3] |
| 2 | [4,1,2,3,null] |
Example 2: Aggregate values in column b using the WHERE clause. If no data meets the filter condition, a NULL value is returned.
mysql > select array_unique_agg(b) from array_unique_agg_example where a < 0;
Keywordsβ
ARRAY_UNIQUE_AGG, ARRAY
