array_sort
Sorts the elements of an array in ascending order.
array_sort(array)
Parametersβ
array: the array whose elements you want to sort. Only the ARRAY data type is supported.
Return valueβ
Returns an array.
Usage notesβ
This function sorts the elements of an array only in ascending order.
NULLvalues are placed at the beginning of the array that is returned.
If you want to sort the elements of an array in descending order, use the reverse function.
The elements of the returned array have the same data type as the elements of the input array.
The following table is used as an example:
mysql> select * from test;
| c1   | c2           |
|    1 | [4,3,null,1] |
|    2 | NULL         |
|    3 | [null]       |
|    4 | [8,5,1,4]    |
Sort the values of column c2 in ascending order.
mysql> select c1, array_sort(c2) from test;
| c1   | array_sort(`c2`) |
|    1 | [null,1,3,4]     |
|    2 | NULL             |
|    3 | [null]           |
|    4 | [1,4,5,8]        |
