Version: Candidate-4.0
array_repeat
array_repeat returns an array containing a given element repeated a specified number of times.
array_repeat(element, count)
  • element: The element to be repeated can be any data type supported by StarRocks.
  • count: The number of repetitions, of type INT.
The data type of the return value is the ARRAY type of element.
Usage notes​
  • When count is less than 1, an empty array is returned.
  • When the element parameter is NULL, the result is an array consisting of count NULLs.
  • When the count parameter is NULL, the result is NULL.
Example 1:
mysql> select array_repeat(1,5) as res;
| res |
| [1,1,1,1,1] |
Example 2:
mysql> select  array_repeat([1,2],3) as res;
| res |
| [[1,2],[1,2],[1,2]] |
Example 3:
mysql> select array_repeat(1,-1) as res;
| res |
Example 4:
mysql> select  array_repeat(null,3) as res;
| res |
Example 5:
mysql> CREATE TABLE IF NOT EXISTS test (COLA INT, COLB INT) PROPERTIES ("replication_num"="1");
mysql> INTO test (COLA, COLB) VALUES (1, 3), (NULL, 3), (2, NULL);
mysql> select array_repeat(COLA,COLB) from test;
| array_repeat(COLA, COLB) |
| [1,1,1] |
| [null,null,null] |
