Version: Candidate-4.0
array_length
Returns the number of elements in an array. The result type is INT. If the input parameter is NULL, the result is also NULL. Null elements are counted in the length.
It has an alias cardinality().
INT array_length(any_array)
any_array: the ARRAY value from which you want to retrieve the number of elements.
Returns an INT value.
mysql> select array_length([1,2,3]);
| array_length([1,2,3]) |
| 3 |
mysql> select array_length([1,2,3,null]);
| array_length([1, 2, 3, NULL]) |
| 4 |
mysql> select array_length([[1,2], [3,4]]);
| array_length([[1,2],[3,4]]) |
| 2 |
keywords​
ARRAY_LENGTH, ARRAY, CARDINALITY
