Version: Candidate-4.0
array_join
Concatenates the elements of an array into a string.
array_join(array, sep[, null_replace_str])
  • array: the array whose elements you want to concatenate. Only the ARRAY data type is supported.
  • sep: the delimiter that is used to separate the concatenated array elements. Only the VARCHAR data type is supported.
  • null_replace_str: the string that is used to substitute NULL values. Only the VARCHAR data type is supported.
Returns a value of the VARCHAR data type.
Usage notes​
  • The value of the array parameter must be a one-dimensional array.
  • The array parameter does not support DECIMAL values.
  • If you set the sep parameter to NULL, the return value is NULL.
  • If you do not specify the null_replace_str parameter, NULL values are discarded.
  • If you set the null_replace_str parameter to NULL, the return value is NULL.
Example 1: Concatenate the elements of an array. In this example, the NULL value in the array is discarded, and the concatenated array elements are separated by underscores (_).
mysql> select array_join([1, 3, 5, null], '_');
| array_join([1,3,5,NULL], '_') |
| 1_3_5 |
Example 2: Concatenate the elements of an array. In this example, the NULL value in the array is substituted with NULL strings, and the concatenated array elements are separated by underscores (_).
mysql> select array_join([1, 3, 5, null], '_', 'NULL');
| array_join([1,3,5,NULL], '_', 'NULL') |
| 1_3_5_NULL |
