array_contains
Checks whether the array contains a certain element. If yes, it returns 1; otherwise, it returns 0.
array_contains(any_array, any_element)
mysql> select array_contains(["apple","orange","pear"], "orange");
| array_contains(['apple','orange','pear'], 'orange') |
|                                                   1 |
You can also check whether the array contains NULL.
mysql> select array_contains([1, NULL], NULL);
| array_contains([1,NULL], NULL) |
|                              1 |
You can check whether the multi-dimensional array contains a certain subarray. At this time, you need to ensure that the subarray elements match exactly, including the element arrangement order.
mysql> select array_contains([[1,2,3], [4,5,6]], [4,5,6]);
| array_contains([[1,2,3],[4,5,6]], [4,5,6]) |
|                                          1 |
mysql> select array_contains([[1,2,3], [4,5,6]], [4,6,5]);
| array_contains([[1,2,3],[4,5,6]], [4,6,5]) |
|                                          0 |
keywordβ
ARRAY_CONTAINS,ARRAY
