percentile_approx_weight
Returns the approximation of the pth percentile with weight. percentile_approx_weight is a weighted version of PERCENTILE_APPROX, and allows users to specify a weight (a constant value or numeric column) for each input value.
This function uses fixed-size memory, so less memory can be used for columns with high cardinality. It also can be used to calculate statistics such as tp99.
DOUBLE PERCENTILE_APPROX_WEIGHT(expr, BIGINT weight, DOUBLE p[, DOUBLE compression])
- expr: The column for which to calculate the percentile.
- pth: Percentile value. Range: [0, 1]. For example,- 0.99indicates the 99th percentile.
- weight: Weight column. It must be a positive constant number or column.
- compression: (Optional) Compression ratio. Range: [2048, 10000]. The larger the value, the higher the precision, the larger the memory consumption, and the longer the calculation time. If this parameter is not specified or the value is beyond the range of [2048, 10000], the default value- 10000is used.
CREATE TABLE t1 (
    c1 int,
    c2 double,
    c3 tinyint,
    c4 int,
    c5 bigint,
    c6 largeint,
    c7 string,
    c8 double,
    c9 date,
    c10 datetime,
    c11 array<int>,
    c12 map<double, double>,
    c13 struct<a bigint, b double>
DUPLICATE KEY(c1)
DISTRIBUTED BY HASH(c1)
BUCKETS 1
insert into t1
    select generate_series, generate_series,  11, 111, 1111, 11111, "111111", 1.1, "2024-09-01", "2024-09-01 18:00:00", [1, 2, 3], map(1, 5.5), row(100, 100)
    from table(generate_series(1, 50000, 3));
-- use constant value as weight
mysql> select percentile_approx_weighted(c1, 1, 0.9) from t1;
| percentile_approx_weighted(c1, 1, 0.9) |
|                         45000.39453125 |
1 row in set (0.07 sec)
-- use a numeric column as weight
mysql> select percentile_approx_weighted(c2, c1, 0.5) from t1;
| percentile_approx_weighted(c2, c1, 0.5) |
|                              35355.9375 |
-- use weight and compression to compute percentile
mysql> select percentile_approx_weighted(c2, c1, 0.5, 10000) from t1;
| percentile_approx_weighted(c2, c1, 0.5, 10000) |
|                                     35355.9375 |
1 row in set (0.09 sec)
Keywordsβ
PERCENTILE_APPROX_WEIGHT,PERCENTILE_APPROX,PERCENTILE,APPROX
