multi_distinct_count
Returns the total number of rows of the expr, equivalent to count(distinct expr).
multi_distinct_count(expr)
Parametersβ
expr: the column or expression based on which multi_distinct_count() is performed. If expr is a column name, the column can be of any data type.
Return valueβ
Returns a numeric value. If no rows can be found, 0 is returned. This function ignores NULL values.
Suppose there is a table named test. Query the category and supplier of each order by id.
select * from test order by id;
| id | country | category | supplier |
| 1001 | US | A | supplier_1 |
| 1002 | Thailand | A | supplier_2 |
| 1003 | Turkey | B | supplier_3 |
| 1004 | US | A | supplier_2 |
| 1005 | China | C | supplier_4 |
| 1006 | Japan | D | supplier_3 |
| 1007 | Japan | NULL | supplier_5 |
Example 1: Count the number of distinct values in the category column.
select multi_distinct_count(category) from test;
| multi_distinct_count(category) |
| 4 |
Example 2: Count the number of distinct values in the supplier column.
select multi_distinct_count(supplier) from test;
| multi_distinct_count(supplier) |
| 5 |
