max_by
Returns the value of x associated with the maximum value of y.
For example, SELECT max_by(subject, exam_result) FROM exam; is to return the subject that has the highest exam score.
max_by(x,y)
Parametersβ
- x: an expression of any type.
- y: an expression of a type that can be ordered.
Return valueβ
Returns a value that has the same type as x.
Usage notesβ
- ymust be a sortable type. If you use an unsortable type of- y, such as- bitmapor- hll, an error is returned.
- If ycontains a null value, the row that corresponds to the null value is ignored.
- If more than one value of xhas the same maximum value ofy, this function returns the first value ofxencountered.
Create a table exam.CREATE TABLE exam (
 subject_id INT,
 subject STRING,
 exam_result INT
Insert values into this table and query data from this table. insert into exam values
 (1,'math',90),
 (2,'english',70),
 (3,'physics',95),
 (4,'chemistry',85),
 (5,'music',95),
 (6,'biology',null);
 | 1 | math | 90 |
 | 2 | english | 70 |
 | 3 | physics | 95 |
 | 4 | chemistry | 85 |
 | 5 | music | 95 |
 | 6 | biology | null |
 6 rows in set (0.03 sec)
Obtain the subject that has the highest score. Two subjects physicsandmusichave the same highest score95and the first subject encountered (physics) is returned.SELECT max_by(subject, exam_result) FROM exam;
 | max_by(subject, exam_result) |
 | physics |
