ds_hll_accumulate
Accumulates values into a HyperLogLog sketch and returns the serialized sketch as a VARBINARY. This function is part of the DataSketches HLL family of functions for approximate distinct counting.
ds_hll_accumulate creates a serialized HyperLogLog sketch that can be combined with other sketches using ds_hll_combine and estimated using ds_hll_estimate.
It is based on Apache DataSketches and provides high precision for approximate distinct counting. For more information, see HyperLogLog Sketches.
sketch ds_hll_accumulate(expr)
sketch ds_hll_accumulate(expr, log_k)
sketch ds_hll_accumulate(expr, log_k, tgt_type)
Parametersβ
- expr: The expression to accumulate into the sketch. Can be any data type.
- log_k: Integer. Range [4, 21]. Default: 17. Controls the precision and memory usage of the sketch.
- tgt_type: Valid values are- HLL_4,- HLL_6(default) and- HLL_8. Controls the target type of the HyperLogLog sketch.
Return Typeβ
Returns a VARBINARY containing the serialized HyperLogLog sketch.
-- Create test table
CREATE TABLE t1 (
  id BIGINT,
  province VARCHAR(64),
  age SMALLINT,
  dt VARCHAR(10)
DUPLICATE KEY(id)
-- Insert test data
-- Basic usage with single argument
SELECT ds_hll_accumulate(id) FROM t1;
-- With custom log_k parameter
SELECT ds_hll_accumulate(province, 20) FROM t1;
-- With both log_k and tgt_type parameters
SELECT ds_hll_accumulate(age, 12, "HLL_6") FROM t1;
-- Group by usage
SELECT dt,
       ds_hll_accumulate(id),
       ds_hll_accumulate(dt)
FROM t1
GROUP BY dt
ORDER BY 1
LIMIT 3;
Related Functionsβ
- ds_hll_combine: Combines multiple serialized sketches into a single sketch
- ds_hll_estimate: Estimates the distinct count from a serialized sketch
- ds_hll_count_distinct: Direct approximate distinct counting function
Keywordsβ
ds_HLL_ACCUMULATE, HLL, HYPERLOGLOG, APPROXIMATE, DISTINCT, COUNT
