bool_or
Returns true if at least one row for expr is true. Otherwise, returns false. boolor_agg is an alias for this function.
bool_or(expr)
Parametersβ
expr: The expression must evaluate to a boolean value, that is, true or false.
Return valueβ
Returns a boolean value. An error is returned if expr does not exist.
Usage notesβ
This function ignores NULL values.
Create a table named employees.CREATE TABLE IF NOT EXISTS employees (
 region_num TINYINT,
 id BIGINT,
 is_manager BOOLEAN
 DISTRIBUTED BY HASH(region_num);
Insert data into employees.INSERT INTO employees VALUES
 (3,432175, TRUE),
 (4,567832, FALSE),
 (3,777326, FALSE),
 (5,342611, TRUE),
 (2,403882, FALSE);
Query data from employees.MySQL > select * from employees;
 | region_num | id | is_manager |
 | 3 | 432175 | 1 |
 | 4 | 567832 | 0 |
 | 3 | 777326 | 0 |
 | 5 | 342611 | 1 |
 | 2 | 403882 | 0 |
 5 rows in set (0.01 sec)
Use this function to check for managers in each region. Example 1: Check if there is at least one manager in each region. MySQL > SELECT region_num, bool_or(is_manager) from employees
 group by region_num;
 | region_num | bool_or(is_manager) |
 | 3 | 1 |
 | 4 | 0 |
 | 5 | 1 |
 | 2 | 0 |
 4 rows in set (0.01 sec)
keywordβ
BOOL_OR, bool_or, boolor_agg
