Version: Candidate-4.0
Information Schema
The StarRocks Information Schema is a database within each StarRocks instance. Information Schema contains several read-only, system-defined views that store extensive metadata information of all objects that the StarRocks instance maintains. The StarRocks Information Schema is based on the SQL-92 ANSI Information Schema, but with the addition of views and functions that are specific to StarRocks.
From v3.2.0, The StarRocks Information Schema supports manage metadata for external catalogs.
View metadata via Information Schema​
You can view the metadata information within a StarRocks instance by querying the content of views in Information Schema.
The following example checks metadata information about a table named table1 in StarRocks by querying the view tables.
TABLE_CATALOG: def
TABLE_SCHEMA: test_db
TABLE_NAME: table1
TABLE_TYPE: BASE TABLE
ENGINE: StarRocks
VERSION: NULL
ROW_FORMAT:
TABLE_ROWS: 4
AVG_ROW_LENGTH: 1657
DATA_LENGTH: 6630
MAX_DATA_LENGTH: NULL
INDEX_LENGTH: NULL
DATA_FREE: NULL
AUTO_INCREMENT: NULL
CHECK_TIME: NULL
CHECKSUM: NULL
CREATE_OPTIONS:
TABLE_COMMENT:
Views in Information Schema​
The StarRocks Information Schema contains the following metadata views:
