Error Codes
This section describes the common error codes for query requests.
| Serial number | Error code | Error message |
| 1005 | Table creation failed. Returns a specific reason. | |
| 1007 | Cannot create a database with the same name. | |
| 1008 | Cannot delete non-existent database. | |
| 1044 | Cannot access unauthorized database. | |
| 1045 | Username and password do not match and therefore cannot access the system. | |
| 1046 | The target database is not specified. | |
| 1047 | An invalid command is specified. | |
| 1049 | An invalid database is specified. | |
| 1050 | A table with the same name already exists. | |
| 1051 | An invalid table is specified. | |
| 1052 | The specified column name is ambiguous and therefore the corresponding column cannot be uniquely identified. | |
| 1053 | An illegal data column was specified for the Semi-Join/Anti-Join query. | |
| 1054 | The specified column does not exist in the table. | |
| 1058 | The number of columns selected in the query statement does not match the number of columns in the query result. | |
| 1060 | There are duplicate column names. | |
| 1064 | There is no surviving BE node. | |
| 1066 | Duplicate table alias appears in the query statement. | |
| 1094 | Thread ID is invalid. | |
| 1095 | The non-owner of a thread cannot terminate the thread. | |
| 1096 | The query statement does not specify the table to be queried. | |
| 1102 | The database name is incorrect. | |
| 1104 | The table name is incorrect. | |
| 1105 | Other errors. | |
| 1110 | Duplicate columns were specified in the subquery. | |
| 1111 | Illegal use of aggregation function in WHEREclause | |
| 1113 | The set of columns in the new table cannot be empty. | |
| 1115 | Unsupported character sets are used. | |
| 1130 | An unauthorized IP address is used by the client. | |
| 1132 | No permission to change user password. | |
| 1141 | Specified entries don’t have privileges to revoke. | |
| 1142 | An unauthorized action was performed. | |
| 1166 | The data column name is incorrect. | |
| 1193 | System variable has invalid name | |
| 1203 | The number of active connections used exceeded the limit. | |
| 1211 | Not allowed to create new users. | |
| 1227 | The user has performed an out-of-authority operation. | |
| 1228 | Session variables cannot be modified by the SET GLOBALcommand. | |
| 1229 | Global variables should be modified by the SET GLOBALcommand. | |
| 1230 | Related system variables do not have default values. | |
| 1231 | An invalid value was set for a system variable. | |
| 1232 | A value of the wrong data type was set for a system variable. | |
| 1248 | No alias was set for an inline view. | |
| 1251 | The client does not support the user authentication protocol required by the server. | |
| 1286 | The storage engine is incorrectly configured. | |
| 1298 | The time zone is incorrectly configured. | |
| 1347 | The object does not match the expected type. | |
| 1353 | The specified column number in the Selectclause of the view is not equal to the defined column number. | |
| 1364 | No default value is set for columns that do not allow NULL values. | |
| 1372 | The password is not long enough. | |
| 1396 | The performed operation failed. | |
| 1471 | The specified table is not allowed to insert data. | |
| 1507 | Delete nonexistent partition, and no condition is specified to only delete existing partitions. | |
| 1508 | All partitions should be deleted by a delete table operation. | |
| 1517 | There are duplicate partition names. | |
| 1524 | The specified plugin has not been loaded. | |
| 1567 | The name of the partition is incorrect. | |
| 1621 | The specified system variable is read-only. | |
| 1735 | The specified partition name does not exist in the table. | |
| 1748 | Data cannot be inserted into a table that does not have a partition. | |
| 1749 | The specified partition does not exist. | |
| 5000 | The specified table is not an OLAP table. | |
| 5001 | The specified storage path is invalid. | |
| 5002 | The name of the specified column should be displayed. | |
| 5003 | The dimension column should be preceded by the index column. | |
| 5004 | The table should contain at least 1 dimension column. | |
| 5005 | The cluster ID is invalid. | |
| 5006 | Invalid query plan. | |
| 5007 | Conflicting query plans. | |
| 5008 | The data insert is only available for data tables with partitions. | |
| 5009 | The PARTITIONclause cannot be used to insert data into tables without partitions. | |
| 5010 | The number of columns in the table to be created is not equal to the number of columns in the SELECTclause. | |
| 5011 | Table reference could not be accessed. | |
| 5012 | The specified value is not a valid number. | |
| 5013 | The time unit is not supported. | |
| 5014 | The table status is not normal. | |
| 5015 | The partition status is not normal. | |
| 5016 | A data import job exists in the partition. | |
| 5017 | The specified column is not a dimension column. | |
| 5018 | The format of the value is invalid. | |
| 5019 | The data replica does not match the version. | |
| 5021 | The BE node is offline. | |
| 5022 | The number of partitions in a non-partitioned table is not 1 | |
| 5023 | No action was specified in the statement used to modify the table or data. | |
| 5024 | Job execution timed out. | |
| 5025 | Data insertion failed. | |
| 5026 | An unsupported data type was used when creating a table via the SELECTstatement. | |
| 5027 | The specified parameter was not set. | |
| 5028 | The specified cluster was not found. | |
| 5030 | The user does not have permission to access the cluster. | |
| 5031 | No parameter specified or invalid parameter. | |
| 5032 | The number of cluster instances was not specified. | |
| 5034 | A cluster with the same name already exists. | |
| 5035 | The number of cluster instances is incorrectly configured. | |
| 5036 | Insufficient BE nodes in the cluster. | |
| 5037 | All databases should be deleted before deleting the cluster. | |
| 5038 | The BE node with the specified ID does not exist in the cluster. | |
| 5040 | No cluster with the same name exists. | |
| 5042 | No permissions. | |
| 5043 | The number of instances should be greater than 0. | |
| 5046 | Source cluster does not exist. | |
| 5047 | Destination cluster does not exist. | |
| 5048 | Source database does not exist. | |
| 5049 | Destination database does not exist. | |
| 5050 | No cluster selected. | |
| 5051 | The source database should be associated with the destination database first. | |
| 5052 | Intra-cluster error: BE node information is incorrect. | |
| 5053 | There is no migration task from the source database to the destination database. | |
| 5054 | The specified database has been associated with the destination database, or data is being migrated. | |
| 5055 | Database associations or data migrations cannot be performed within the same cluster. | |
| 5056 | Database cannot be deleted: it is associated with another database or data is being migrated. | |
| 5056 | Database cannot be renamed: it is associated with another database or data is being migrated. | |
| 5056 | Insufficient BE nodes in the cluster. | |
| 5056 | The specified number of BE nodes already exists in the cluster. | |
| 5059 | There are BE nodes in the cluster that are in the offline state. | |
| 5063 | The type name is incorrect. | |
| 5064 | Generic error message. | |
| 5063 | The Colocate feature has been disabled by the administrator. | |
| 5063 | A colocate data table with the same name does not exist. | |
| 5063 | The Colocate table must be an OLAP table. | |
| 5063 | Colocate tables should have the same number of replicas. | |
| 5063 | Colocate tables should have the same number of split buckets. | |
| 5063 | Colocate tables should have the same number of partition columns. | |
| 5063 | Colocate tables should have the same data type of partitioned columns. | |
| 5064 | The specified table is not a colocate table. | |
| 5065 | The specified operation is invalid. | |
| 5065 | The specified time unit is illegal. The correct units are DAY,WEEK, andMONTH. | |
| 5066 | The start value of the dynamic partition should be less than 0. | |
| 5066 | The start value of the dynamic partition is not a valid number. | |
| 5066 | The end value of the dynamic partition should be greater than 0. | |
| 5066 | The end value of the dynamic partition is not a valid number. | |
| 5066 | The end value of the dynamic partition is null. | |
| 5067 | The bucket number of the dynamic partition should be greater than 0. | |
| 5067 | The bucket number of the dynamic partition is not a valid number. | |
| 5066 | The bucket number of the dynamic partition is empty. | |
| 5068 | Whether to allow dynamic partition where the value is not a valid boolean: true or false. | |
| 5069 | The name of the specified dynamic partition has an illegal prefix. | |
| 5070 | The specified operation is disabled. | |
| 5071 | The number of replicas of the dynamic partition should be greater than 0. | |
| 5072 | The number of replicas of the dynamic partition is not a valid number. |
